FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
AI Subtitles
Have you ever encountered the following challenges while editing screen recordings?
"I want to automatically generate subtitles for my videos based on my voice narration, but I don't know where to start?"
"The generated subtitles contain typos, and I don't know how to fix them for better accuracy?"
If you have these or similar needs, FocuSee's AI subtitles feature offers a solution. It supports subtitle generation in multiple languages, automatically recognizes microphone audio, and helps you quickly generate subtitles, while also allowing for manual adjustments and optimization. The following guide will detail how to automatically add subtitles to your screen recordings, easily solving your subtitle creation challenges.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
AI Credits Calculated Rules
AI Feature AI Credits Calculated Rules
AI Subtitles 1 Credit/Minute
Step 1. Device Setup.
Before starting screen recording, please enable your microphone, system audio, or headphones to ensure sound is recorded properly.
Device Settings
Device Settings
Step 2. Add Subtitles.
When the video recording is completed, FocuSee will automatically enter the editing page. In the menu on the left side of the software interface, click Captions function, and enter the subtitle generation interface.
Click AI subtitles
Click AI subtitles
Then, FocuSee will automatically take you to the following interface. You can choose the Advanced Model for higher accuracy and broader language support (credits required), or use the Local Model completely free of charge. For details on free feature, refer to the Captions Guide. For this guide, please select Advanced Model.
Select Advanced Model
The AI subtitles function requires the consumption of corresponding credits. If you have any questions about this, please click here for details.
Step 3. Select Advanced Model and Set Subtitle Language
FocuSee can recognize the language of the audio recorded by the microphone. You can choose automatic recognition as needed, or select a specific language in the language drop-down menu.
Select Language
Select Language
Step 4. Generate and Adjust Subtitles.
After setting the language, you can click the Generate button to generate subtitles. This process takes time, depending on factors such as video size and audio length. Please be patient.
Generate Subtitles
Generate Subtitles
After the subtitles are generated, you can directly view all the subtitles in the left area of the software editing page, check and adjust the text that needs to be modified sentence by sentence.
Check Subtitles
Check Subtitles
If you need to optimize the subtitle display effect, you can click the Style to customize the subtitle Font Size, Position, and Spacing.
Optimize Parameters
Optimize Parameters
If you need to turn off subtitles, click the Back button to return to the previous interface, where you can Enable or View Subtitles.
If you need to regenerate subtitles, select the Advanced Model and Regenerate.
Back to Regenerate Subtitles
Step 5. Share and Export Video.
After completing all subtitle editing and styling settings, you can click the Play button to view the works. Then, you can click the Share or Export button to share or export your video.
Share and export
Share and export
If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
