FocuSee Guide
Learn how to make screen recordings with automatic zoom-in on the video with FocuSee. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Captions
"I want my video to automatically generate captions based on my audio. How can I do this?”
“Some words in my video's captions are wrong. How can I adjust it?”
If you come across similar situations as mentioned above, please don’t worry. FocuSee-Captions function can help you enable the automatic generation and manual adjustment of the captions. You can refer to this instructions to learn how to incorporate captions into your video.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
The Difference between Advanced Model & Local Model
Advanced Model Local Model
1 Credit/Minute No Credit Consumption
Step 1. Device Setup.
Before starting the screen recording process, please enable your microphone, system audio or headphones.
Device Setup
Device Setup
Step 2. Add Captions.
After the video recording is completed, please click Captions in the left menu.
Click Captions
Click Captions
Then, FocuSee will automatically take you to the following interface. You can choose the Advanced Model for higher accuracy and broader language support (credits required), or use the Local Model completely free of charge. For this guide, Please select Local Model.
Select Local Model
Select Local Model
Within this tab, you will find 3 auto caption generation modes: Nano, Basic, and Pro. Each mode offers varying levels of accuracy in caption generation.
Choose a Model
Choose a Model
Discover how to record videos using FocuSee. Click here for in-depth instructions.
Step 3. Set Caption Language.
Please select either the Auto option or a specific language from the Language section according to your needs. Currently, this feature supports ten languages, including English, French, German, Spanish, Italian, Japanese, Simplified Chinese, Traditional Chinese, Korean, and Portuguese.
Choose a Language
Choose a Language
Step 4. Generate Captions.
Then click the Generate Captions.
Click the Generate Captions
And the captions will be generated automatically. You can adjust the captions on the left side.
Adjust the Captions
Adjust the Captions
You also can select the Style icon to customize the Font Size, Position, and Spacing of the captions.
Select the Style
Select the Style
If you need to regenerate captions, please click the Back button to return to the previous setting page and select Local Model to regenerate.
Click Back Button
Click Back Button
Then you will see the following page, where you can Enable or View Subtitles.
Step 5. Export video.
After you finish the captions, you can click the Play button to view the works. Then, you can click the Share or Export button to share or export your video.
Share and Export
Share and Export
If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
