FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Record Computer Screen, Webcam & Audio
Here are some user queries we have gathered regarding screen recording. Have you encountered similar issues?
“What app do you recommend recording a video on my computer with both camera and audio?”
“How can I streamline screen recording and simplify post-production for recordings without manual editing?”
If you have similar questions and needs, don't worry. FocuSee offers three screen recording choices, enabling you to capture the whole screen, a customized section, or a specific window, with the capability to record audio and webcam simultaneously.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
Supported Video Output Formats
MP4, GIF
Supported Video Resolution
480P, 720P, 1080P, 2K, 4K
Step 1. Download and Install FocuSee on Computer.
Visit our official website and get FocuSee downloaded onto your computer. Ensure you have a stable network connection during the download and installation process. Follow the prompts on the screen to install FocuSee.
Step 2. Configure Settings before Recording.
Launch FocuSee on your computer. the video creation interface will be displayed. Prior to recording, please select your webcam, microphone, and speaker.
Hardware Setup of FocuSee
1Camera Setting: Tab the Camera icon to enable or disable the webcam. Click on the dropdown option to access the compatible webcams on your computer and choose the preferred one.
2Microphone Setting: Tab the Microphone icon to enable or disable the microphone. Click on the dropdown menu to view the list of compatible microphones on your system and select your desired option.
3System Audio: Click on the System Audio icon to toggle system audio on or off. Access the dropdown menu to display the list of supported system audio devices on your computer and choose the desired one. It also supports selecting to record audio from a selected application only.
4Teleprompter: Click the Teleprompter icon from the bottom-right corner in the recording mode interface. Here, you can easily customize the teleprompter's scrolling speed, font size, color, and background transparency. Click here to explore advanced teleprompter usage tips.
1. You have the option to initiate rapid recordings without having to open the FocuSee window. On Mac, it appears in the upper navigation bar, whereas on Windows, it is integrated into the lower system tray, allowing you to promptly access three recording modes. Click here for additional information.
2. If no camera, microphone, or speaker is detected on your computer, it will show no corresponding device detected. Please ensure that the devices are available to record the content you desire.
Step 3. Select the Recording Mode.
FocuSee offers three screen recording modes for capturing your computer screen: full screen, a customized area, or a specific window. Simply click the Full Screen, Custom, or Window icon based on your needs.
If you choose to record a customized region or a particular window, after clicking on the Custom or Window icon, please drag a desired area or choose a specific window for recording. Then you can choose/change the camera, microphone, and system audio settings.
Step 4. Initiate Recording.
Adjust your camera, microphone, and audio settings as necessary, then initiate recording by clicking the purple REC button.
Adjust Settings
Adjust Settings
Step 5. Wait for the Recording Countdown.
Before the recording starts, there will be a 3-second countdown to prepare. Once the countdown ends, FocuSee will start recording. You can then begin your presentation at your own pace.
Recording Countdown
Recording Countdown
There are no restrictions on recording duration as long as your computer supports the desired timeframe.
Step 6. Complete the Recording Process.
After completing the recording, click the purple button to conclude the recording.
End Recording
End Recording
Step 7. Edit the Video.
Following the recording, the video automatically integrates zoom effects. Moreover, you can perform fundamental video editing tasks such as cutting, adjusting playback speed, and highlighting specific areas using the tracking feature.
Edit the Video
Edit the Video
Please click the following post to learn more about video editing details: Edit the Recording.
Step 8. Export the Video.
Once editing is finished, the video can be exported in MP4 or GIF format.
Export the Video
Export the Video
Before exporting the video, you can set the video output parameters on this interface.
1Name: The name by which the video file will be saved.
2Save Path: The location on your computer where the video will be saved.
3Format: The video format in which the video will be saved as MP4 or GIF format.
4Frame Rate: Set the frame rate to 10, 20, 24, 25, 30, 50, or 60 frames per second (FPS).
5Resolution: 480P, 720P, 1080P, 2K, 4K or Original resolution.
6Quality: Higher video quality results in better image clarity, but also increases project file size and export time.
If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
