FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Removal of Silences and Filler Words in Videos
Here are some common challenges video creators face when using FocuSee. Do these sound familiar?
"My recording has long silent gaps—how can I remove them without re-recording?"
"I often say 'um' or ' Hmm' during my video. Can FocuSee help me cut these filler words automatically?"
The Remove Silence & Fillers feature in FocuSee helps you clean up your recordings by automatically detecting and removing unnecessary pauses and verbal fillers. This makes your videos smoother, more professional, and easier for viewers to follow. Here you will learn how to detect, remove, and fine-tune silences and filler words with just a few clicks.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
AI Credits Calculated Rules
AI Feature AI Credits Calculated Rules
Remove Silence & Fillers 1 Credit/Minute
Step 1. Download and Install FocuSee on Your Computer.
Visit our official website and get FocuSee downloaded onto your computer. Ensure that you have a stable network connection during the download and installation process. Follow the prompts on the screen to install FocuSee.
Click here for a complete walkthrough of the download and installation process.
Step 2. Launch FocuSee.
Open FocuSee on your computer. You can either record a new video or select an existing one to begin editing.
Access the Editing Interface
Step 3. Choose Smart Cut Mode.
In the left panel of the editing interface, select Smart Cut to enter the silence and filler words removal feature. This AI-powered feature automatically trims unnecessary silences and filler words for smoother, natural speech flow.
Next, select the source language or let FocuSee auto-detect it, then click Start Recognition.
Click the Start Recognition
This feature consumes credits based on the length of the audio. If subtitles have already been generated, you can use them directly for free. However, re-recognizing the audio will consume credits, and the results will not be synchronized with the subtitles module.
Step 4. Check Recognition Results.
After clicking Start Recognition option, it will start detecting silent gaps and filler words, please keep patience.
AI Recognition Process
Once the recognition is complete, you will be taken to the Results page, where all detected silences and filler words are highlighted in the transcription. The Delete button shows the total number of segments selected by default. You can also manually select and remove any silent gaps or filler word segments as needed.
Step 5. Remove Silence and Filler Words.
After confirming the segments you want to delete, click Delete button.
Click Delete Button
Click Delete Button
Once deletion is complete, the number next to the Delete button will update to 0, confirming that the unwanted silences and filler words have been successfully removed.
Remove Silence and Filler Words Successfully
Step 6. Filter and Reset (Optional).
By default, all recognized subtitle files are displayed, including those that have been deleted. Click the Filter icon to hide deleted segments or display all segments.
Click Filter Icon
Click Filter Icon
If needed, click Reset button to restore deletion and selection settings to the initial recognition state.
Click Reset Button
Click Reset Button
If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
