FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Add Watermark
“What should I do if I need to add my own watermark to videos?”
“How do I add a watermark to protect my video content from unauthorized use?”
If you come across similar situations as mentioned above, please don't worry. FocuSee can support the feature of adding custom watermarks to videos. It not only protects your content from unauthorized use but also enhances your brand image. The following guide will help you on how to add a custom watermark to videos.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
Supported Watermark Image Formats
PNG, JPG, JPEG, SVG, and etc.
Differences between Trial & Activated Version
Benefits Trial Version Activated Version
Add Watermarks
Part 1. How to Upload Watermark?
Step 1. Download FocuSee on Your Computer.
Before you perform any function operation, please download and install FocuSee on your computer. Please make sure the network is stable while downloading and installing FocuSee on your computer.
Step 2. Record Your Video.
After FocuSee is installed on the computer, please launch the program. Then, you will enter the main window of FocuSee displayed as below. Please select one recording mode to record your video.
Choose Recording Mode
Step 3. Upload Your Watermark.
After the video recording is completed, please click on the Watermark button and you will see the following interface. The Show Watermark button is enabled by default, and you can directly upload or drag and drop your watermark image from your computer.
FocuSee supports watermark image formats such as PNG, JPG, JPEG, and SVG.
Part 2. How to Edit Your Watermark?
Step 1. Enter the Interface with Watermark.
After the watermark is uploaded, you will see the interface as below:
Watermark Interface
Watermark Interface
Step 2. Edit Your Watermark.
In the interface, you can adjust the position, size, and opacity to edit your watermark.
Edit Your Watermark
Edit Your Watermark
In this preview interface, you can edit the watermark by:
1 Adjusting the position
2 Adjusting the size
3 Adjusting the opacity
FocuSee currently only supports image watermarks.
Part 3. How to Delete and Replace the Current Watermark?
Step 1. Delete the Current Watermark.
If you want to delete current watermark, please hover your mouse over the current image, and a delete button will appear. Simply click on it to remove the current watermark from the video.
Step 2. Replace The Current Watermark.
Please click the "click, drag, and paste to upload image" options box to replace the current image.
1. The free version of FocuSee only supports uploading custom watermarks and preview their effect in videos. If you need tp export videos with custom watermarks, please upgrade Focusee to enjoy this feature.
2. If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
