FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Edit the Recording
“I have recorded a video with FocuSee, how can I crop the video?"
"I'm looking for an all-in-one software solution for recording and editing videos, with features like zooming in on specific areas and adding mouse click effects. Any suggestions?"
If you encounter situations like those described above, there’s no need to worry. The Edit the Recording feature allows you to modify videos recorded with FocuSee, and also supports importing videos for editing. This mode helps enhance the visual appeal and engagement of your videos. Please refer to the detailed instructions to begin editing.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
Part 1. Background Canvas Settings
Step 1. Jump to the Recording Editing Interface.
After recording your screen, you will automatically jump to the recording editing interface.
Discover how to record videos using FocuSee. Click here for in-depth instructions.
Step 2. Choose the Video Enhancement Option.
Please select the Video Enhancement option. This will take you to the Background Canvas Settings interface, where you can adjust the size and style of the video canvas to suit your preferences. Additionally, you can customize the video background as well.
Choose Video Enhancement Option
Step 3. Set Video Canvas Size.
By default, FocuSee sets the size of your video canvas to auto-size. If you want to resize the canvas, FocuSee offers another four commonly - used video sizes: 1:1, 4:3, 16:9, and 9:16. This enables you to adjust the dimensions of your video to meet your specific needs.
FocuSee provides the option to customize the canvas size for sharing on diverse social media platforms such as YouTube, TikTok, Twitter, LinkedIn, Facebook, and Instagram. This guarantees that your video is optimized for each specific platform and retains its visual allure when shared across different social media channels.
Step 4. Set Video Canvas Style.
In addition to adjusting the video size, FocuSee also lets you set a fixed zoom part and customize the padding, inset, roundness, shadow, and background blur to create a more polished and visually refined look.
1Fixed Zoom Part: To choose whether you want to fix the zoomed-in section in the video.
2Padding: This parameter governs the spacing between the video content and the edges of the canvas. When the padding value is increased, more space is added; conversely, decreasing it reduces the gap.
3Inset: The inset parameter determines the distance between the video content and the canvas borders. By adjusting this value, you can alter how closely the video is positioned within the canvas.
4Roundness: The roundness parameter allows you to modify the corners of the video canvas. Increasing the roundness value results in more rounded corners, while decreasing it yields sharper edges.
5Shadow: The shadow parameter controls the presence and intensity of a shadow effect around the video canvas. Adjusting this value enables you to add or reduce the prominence of the shadow.
6Background Blur: Adds a blur effect to the canvas background to reduce visual distractions and keep the focus on the video content, creating a cleaner and more focused look. (Currently available on Mac only. The Windows version is coming soon.)
If you are recording an Android or iOS device, you can add a device frame, such as an iPhone, iPad, Android phone, or tablet, around your recorded screen to give your video a more professional appearance.
Set Device Frame
Set Device Frame
Step 5. Set Background.
Additionally, we offer a variety of video background templates, allowing you to easily add or change the background of your video.
Set Background
Set Background
Part 2. Cursor Settings
Once you have finished recording your screen, you will be automatically redirected to the recording editing interface. At this point, please select the Cursor Option.
Click Cursor Option in Recording Editing Interface
Step 2. Configure Cursor.
The Cursor tab provides you with the ability to adjust the mouse size, choose from a variety of mouse styles, add mouse click sounds, apply different cursor effects, and hide mouse if not moving. Customizing the mouse cursor allows you to personalize your experience and enhance visual and audio feedback for mouse interactions.
Configure Mouse Cursor
For more details about mouse settings, please click here to view additional information about camera features.
Part 3. Camera Layout Settings
Once you have finished recording your screen, you will be automatically redirected to the recording editing interface. At this point, please select the Camera Option.
Click Camera Option in Recording Editing Interface
Step 2. Configure Camera Display.
In the Camera module, you can choose whether to show or hide the camera and switch between different camera styles. By clicking AI Avatar, you can jump directly to the AI Camera feature. You can also freely adjust the camera's position and layout, set it to full-screen mode, and remove the background for a cleaner look.
In addition, you can resize the camera window and adjust its roundness, apply portrait mirroring, dynamically scale the camera during zooming, and enhance visuals with filters. A variety of camera borders are also available to give your video presentations a more polished and professional appearance.
Configure Camera Settings
1. Learn more about Camera Layout: Learn how to adjust, resize, and arrange your camera to achieve optimal video composition and enhance visual quality.
2. Discover AI Avatar features: Explore how to replace your real webcam feed with a virtual AI avatar for a creative presentation style.
3. Remove Camera Background Guide: Follow step-by-step instructions to remove or replace your background for a cleaner, distraction-free look.
Part 4. Crop the Video
Once you have recorded your screen using FocuSee, you will be automatically redirected to the recording editing interface.
Step 2. Crop Video.
Then, please click the Crop icon to start cropping the video.
Click Crop Icon
Click Crop Icon
In this feature, we provide four preset aspect ratios for your convenience: 16:9, 4:3, 1:1, and 9:16. Additionally, FocuSee offers you the freedom to customize the video size, enabling you to have full control over the visual presentation of your video.
Crop the Video
Crop the Video
Part 5. Clip Settings
Step 2. Click Clip Icon to Start Cliping Video.
Please click on the timeline at the desired location to select the section you want to cut, then tap the Clip icon to split your video into separate clips.
Click Clip Icon
Click Clip Icon
Step 3. Manage Video Clips.
And you can click on each clip to adjust its speed to your preference. The settings can also apply to all video clips.
Adjust Video Clips Speed
You can toggle the Show Cursor option to flexibly control whether the mouse cursor appears in this clip.
Turn on Show Cursor
Turn on Show Cursor
In addition, you can adjust the audio settings for the selected video clip, allowing you to individually adjust the system audio, microphone, and device audio for the selected clip. (Currently available on Mac only. The Windows version is coming soon.)
Adjust Current Clip Audio
Additionally, to remove any unwanted parts from the video, simply click the Delete button.
Delete Unnecessary Video Clips
Part 6. Zoom Settings
Step 2. Manage Zoom Settings.
FocuSee incorporates an automatic zoom-in effect during screen recording. However, if you find that the zoom-in effect is unnecessary for your recording, you have the option to disable it. Please choose the Zoom clips and click the Disable Zoom button.
Click Disable Zoom Button
If you choose to keep the zoom settings, you can set the zoom size as well as manually adjust the position of the video zoom.
Set Zoom Size and Adjust Position
To add a new zoom to your recording, simply click on the zoom timeline at the desired location.
Add New Zoom
Add New Zoom
Part 7. Spotlight Settings
After recording your screen with FocuSee, you will automatically jump to the recording editing interface.
Step 2. Choose Spotlight.
Select Annotations from the left toolbar, click the desired location where you want to add the spotlight, and then click the Spotlight icon in the annotation toolbar.
Click Spotlight Icon
Step 3. Manage Spotlight Effect.
Then, you can customize its size and shape by adjusting the spotlight round. With this effect, you have the flexibility to add spotlights to various parts of your video, such as the title, important features, images, and other elements.
Customize Size and Shape of Spotlight
If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
