FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Permissions and Settings
"My computer runs on macOS 10.15, but I'm unable to use FocuSee because it's asking me for permission. What should I do?"
"I want to use keyboard shortcuts with FocuSee. How can I complete the relevant settings for keyboard shortcuts?"
If you encounter similar situations as mentioned above, there is no need to worry. The Permissions and Settings section will guide you to complete granting permission on your computer and configure the settings of the FocuSee.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
Part 1. Grant Permission on Mac Computer
Due to macOS privacy policies, FocuSee requires screen, camera, and microphone permissions, as well as driver installation, to function properly. Please follow the instructions below to grant the necessary permissions.
Step 1. Download and Install FocuSee on Computer.
Visit our official website and download FocuSee on to your computer. Make sure you have a stable network connection during the download and installation process. Follow the on-screen prompts to install FocuSee.
Step 2. Enable System Privileges.
Upon initial launch on Mac computers, the app will request permission to access the screen, camera, microphone, and drivers installation for recording capabilities. If you have unauthorized permissions for your microphone, camera, etc., you will get a popup to grant permissions when you click any of the icons or features.
For macOS 13 and later, you can record audio without installing an extra driver. However, if you're using macOS 13 earlier, you'll need to install the audio driver for smooth recording.
Let's take Camera permission granting as an example. Please click Enable button to continue the process.
Click Enable Button
Click Enable Button
Step 3. Grant Permissions.
Then, it will open your Mac computer's System Settings - Privacy & Security settings - Camera to complete the Camera Permission Authorization. After authorization, please restart FocuSee to ensure that the permission authorization is successful.
Grant Camera Permission
Part 2. How to Enable Microphone Privacy on Windows Computer
If you're using Windows computer and encounter a prompt about microphone privacy when starting a recording in FocuSee, it's likely because the microphone access is disabled in your system settings. To record your voice, you'll need to enable microphone privacy by following the steps below. This ensures that FocuSee can access your microphone seamlessly.
Step 1. Open Microphone Privacy Settings.
In the Windows search bar, type "Microphone privacy settings" and open it. You can also go to "Settings" > "Privacy" > "Microphone".
Type Microphone privacy settings
If the search bar is not visible, right-click on the Windows taskbar, select "Search", and enable "Show search box".
Select Search and Enable Show search box
Step 2. Open Microphone Privacy Settings.
In the Microphone privacy settings, toggle the switch to "On" for "Allow apps to access your microphone".
Allow Apps to Access Your Microphone
Step 3. Allow Desktop Apps to Access Your Microphone.
Then, please scroll down and ensure the option for "Allow desktop apps to access your microphone" is also turned "On".
Step 4. Restart FocuSee.
Finally, close and restart FocuSee, then try recording again. Your microphone should now work seamlessly during recordings.
Restart FocuSee
Restart FocuSee
Part 3. How to Enable Camera Privacy on Windows Computer
If you're using Windows computer and encounter a prompt about camera privacy when starting a recording in FocuSee, it's likely because the camera access is disabled in your system settings. To record your webcam, you'll need to enable camera privacy by following the steps below. This ensures that FocuSee can access your camera seamlessly.
Step 1. Open Camera Privacy Settings.
In the Windows search bar, type "Camera privacy settings" and open it. You can also go to "Settings" > "Privacy" > "Camera".
Type Camera privacy settings
If the search bar is not visible, right-click on the Windows taskbar, choose "Search", and tick "Show search box".
Step 2. Allow Apps to Access Your Camera.
In the Camera privacy settings, toggle the switch to "On" for "Allow apps to access your camera".
Step 3. Allow Desktop Apps to Access Your Camera.
Then, please scroll down and toggle the switch to "On" for "Allow desktop apps to access your camera".
Finally, close and restart the FocuSee you want to use with the camera. Your camera should now work seamlessly during recordings.
Restart FocuSee
Restart FocuSee
Part 4. Configure the Settings of FocuSee
Step 1. Download and Install FocuSee on Your Computer.
Step 2. Enter the Settings Interface.
Launch FocuSee on your computer and click on the Settings icon on the right-upper corner of the interface.
Click Settings Icon
Click Settings Icon
Next, you will see the FocuSee Settings interface, which includes General, Record, Shortcut Keys, and Export settings.
Step 3. Finish General Settings.
For General settings, you can change Save Location, Export Location, choose whether FocuSee starts automatically on power-up, and enable auto play video when entering the editor.
General Settings
General Settings
Step 4. Finish Record Settings.
Click the Record option to apply your settings, including automatically adding Zoom effects, hiding desktop icons, hiding the taskbar, setting recording quality, and configuring the countdown before recording.
Screen Recording Shortcut Keys Settings Interface
Configure Record Settings
Step 5. Finish Shortcut Keys Settings.
To complete the Recording Shortcut Keys Settings, please click the Record under Shortcut Keys option.
With Record Shortcut Keys Settings interface, you can finish the below settings:
1New Recording: Initiate a new screen recording.
2Full Screen: Record your entire computer screen.
3Custom: Select a specific area on your screen to record.
4Window: Choose a window to record.
5Pause/Continue Recording: Pause or continue your screen recording.
6Finish Recording: Stop your screen recording when you finish recording.
Click the Edit button to open the Editing Shortcuts Key Settings page.
Screen Editing Shortcut Keys Settings Interface
With screen editing Shortcut Keys Settings interface, you can finish the below settings:
1Clip: Cut your video into specific segments, which can be trimmed, manipulated, and arranged within the editing timeline.
2Crop: Adjust the frame to remove unwanted areas or to highlight a specific subject or element within the video.
3Add Zoom: Apply a zoom-in effect to a specific portion of a video clip, magnifying the scale of the selected area.
4Save: To save the recorded file.
5Save as: To save the recorded file as another copy file.
6Move to Timeline Start: Instantly jump the playhead to the beginning of the timeline.
You can move your cursor to the next content area to reveal additional editing options and customize keyboard shortcuts.
Show More Editing Shortcuts
1Move to Timeline End: Move the playhead to the last frame of the timeline.
2Zoom In Timeline: Zoom in on the timeline for more precise editing.
3Zoom Out Timeline: Zoom out the timeline to see more of your project at once.
4Copy Properties: Copy the current effect or clip settings for reuse.
5Paste Properties: Apply the copied settings to another clip or effect.
6Open History: View and navigate through your recent recordings.
7Undo: Revert the most recent action.
8Reset: Restore the selected settings to their default values.
Step 6. Finish Export Settings.
Click the Export button to configure the video format, resolution, frame rate, and recommended settings. Once applied, FocuSee will use these settings by default for all future video exports, ensuring consistency and professional-quality output.
Configure Export Settings
If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
