Free Download For Win & Mac | 100% Clean & Secure
Here are some common challenges video creators face when using FocuSee. Do these sound familiar?
"How do I blur a face or text in FocuSee without covering the whole screen?"
"Can I blur part of my video? For example, hiding personal info while keeping the rest clear?"
The Blur Effect in FocuSee allows you to selectively obscure sensitive or distracting areas of your screen recordings. You can add blur effect to redact private or sensitive information, such as passwords, personal data, or confidential details, in your recordings. Here you will know how to apply, adjust, and customize the blur effect.
| Windows | Mac | |
| Operating System | Windows 10 or later | macOS 10.15 or later, and optimal experience on macOS 12.3 and above |
| Processor | Intel i5 and above processors, dual-core 2.9GHz and above | Apple M1 or later or Intel-based Mac |
| Memory | At least 8GB of RAM | At least 8GB of RAM |
| MP4, GIF |
Visit our official website and get FocuSee downloaded onto your computer. Ensure that you have a stable network connection during the download and installation process. Follow the prompts on the screen to install FocuSee.
Click here for a complete walkthrough of the download and installation process.
Open FocuSee on your computer. You can either record a new video or choose an existing one to access the editing interface.
Access the Editing Interface
Click the Annotation function on the left, select the Blur option under the Mask category, and then you can add a blur effect.
Add Mosaic Effect
On a Blur track, you can add multiple blur effects at the same time, or add them at different times.
Add Blur Track
Use the selection tool to define the area you want to blur.
Define the Area
Click the Blur Effect on the track, you can control the intensity of the blur effect (higher values create a more pronounced blur) and adjust the shape of the blur, allowing for softer or more elliptical effects.
Adjust the Blur settings
After finalizing your edits, save the video. Click on the Export button to save your video in the desired format. Or you can upload the video to share with your audience.
Export Your Video
1. To know more information on how to clip the video with FocuSee, please refer to this detailed guide.
2. If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
