FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Cursor Effect
The Cursor Effect in FocuSee lets you enhance the visibility of your mouse pointer and highlight its actions. This feature is especially useful for tutorials, product demos, software walkthroughs, or any video where you want viewers to clearly see where and how you interact with your screen.
You can customize the cursor size, style, click animations, and sound effects to make your actions stand out and guide your audience's attention more effectively.
Part 1. What is Cursor Effect?
The Cursor Effect in FocuSee is a powerful editing tool that makes your mouse pointer more visible and interactive in recorded videos. By customizing the cursor's appearance, animations, and sounds, you can draw your audience's attention to exactly where you are clicking or moving on the screen, ensuring they never miss an important action.
Part 2. How to Apply Cursor Effect?
Step 1. Enter the Recording Editing Interface of FocuSee.
Open FocuSee on your computer. You can either record a new video or choose an existing one to access the editing interface.
Access the Editing Interface
Step 2. Click the Cursor Button.
Click the Cursor button to enter the cursor effect panel. In this panel, you can enable cursor effects by toggling on the Show Cursor option.
Click Cursor Button
Click Cursor Button
Step 3. Customize Cursor Effect.
Afer that, please adjust the cursor size as needed.
Set Cursor Size
Set Cursor Size
Next, you may select a cursor style from a variety of available options, allowing you to further personalize the appearance of your mouse.
Set Cursor Style
Set Cursor Style
After selecting your preferred cursor style, adjust the Cursor Angle and Dynamic Cursor Direction. Dynamic Cursor Direction automatically rotates the cursor based on its movement for more natural and fluid motion.
Adjust Cursor Angle and Dynamic Cursor Direction
To emphasize your clicks in recordings, choose a preferred click effect. Once enabled, a visual effect will appear with each click, making your actions more noticeable and easier for viewers to follow.
Set Cursor Click Effect
Then, in the Cursor Click Sound section, toggle the switch to enable cursor click sounds, choose your preferred sound from the available options, and adjust the volume as needed.
Set Cursor Click Sound
If you don't need the cursor click sound, simply turn it off. Once disabled, the interface will appear as shown below.
Turn off Cursor Click Sound
In addition to the cursor style, click effects, and sound effects, you can also customize the settings under Smart Optimization for a more natural and fluid recording experience. For example, you can enable Hide Cursor When Idle, customize the idle duration, and choose a hide or show animation to keep the screen clean and minimize distractions. You can also enable Smooth Cursor Path and adjust the smoothing level to refine cursor motion during recording, making the cursor path smoother and more natural.
Smart Cursor Optimization
You can also customize the Cursor Position at End of Video, choosing to keep the cursor in its current position or return it to its starting position, and adjust the duration of the ending animation. This gives you greater control over how the cursor pauses or returns at the end of the video, helping it transition naturally with the video’s pacing for a smoother viewing experience.
Set the Cursor Position at the End of the Video
Step 4. Save and Export Your Video.
After finalizing your edits, save the video. Click on the Export button to save your video in the desired format. Or you can upload the video to share with your audience.
Export Your Video
Export Your Video
1. To know more information on how to clip the video with FocuSee, please refer to this detailed guide.
2. If you have further questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
