FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos.Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
AI Avatar
Here are some common challenges video creators face when using FocuSee:
"Is there a way for me to be the face of my channel without actually showing my face?"
"I want to create video content using my camera, but without appearing in it myself."
If these challenges resonate with you, FocuSee's AI Avatar feature provides the solution. This feature uses text or audio input to generate realistic virtual personas that can deliver your message professionally while maintaining visual appeal.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
Differences Between Free & Activated Versions, and AI Credits Calculated Rules
With FocuSee free version, you can record and edit videos, and export one video with a FocuSee watermark. If you'd like to export videos without restrictions or watermarks, we recommend upgrading to an Activated Plan. Please note that the AI Avatar feature requires additional AI credits.
Benefits Free Version Activated Version AI Credits Calculated Rules
Record Video /
Edit the Recording /
Zoom-in Effect /
Motion Blur Effect /
AI Avatar 150 Credits/Minute
Add Watermark /
Export Video 1 (With Watermark) Unlimited (No Watermark) /
Share Video /
Step 1. Download and Install FocuSee on Your Computer.
Visit our official website and get FocuSee downloaded onto your computer. Ensure that you have a stable network connection during the download and installation process. Follow the prompts on the screen to install FocuSee.
Click here for a complete walkthrough of the download and installation process.
Step 2. Select AI Avatar.
Launch FocuSee and navigate to the AI Avatars section. Browse through our extensive library of virtual personas by selecting View All or choose from recommended options. Select your preferred camera background and audio settings to match your video requirements. Click Generate button.
Select AI Avatar
Select AI Avatar
Step 3. Generate Your AI Avatar.
Initiate the generation process. This may take some time depending on the complexity of your selected avatar and settings. You can continue editing other aspects of your project while the generation is in progress. Check the status of your avatar generation in the AI Task Center on the top-right of your screen.
Generate AI Avatar
Generate AI Avatar
Step 4. Review and Apply Your Avatar.
Once generation is complete, view your custom avatar under the My avatar section. Preview how it appears and select Apply to camera to integrate it into your recording setup.
Apply Avatar
Apply Avatar
Step 5. Customize AI Avatar Layout.
Click on the Camera option to adjust your avatar's positioning, size, and cropping within the frame. Fine-tune these settings to achieve the perfect composition for your video.
1. For more details on configuring your camera layout, including positioning and cropping, please refer to the Camera Layout Guide.
2. If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
