FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Recording Preset
“I want to pre-set the size of the camera in my recording, what should I do?”
“Is there a good way to keep the setting in my recordings so that I can use it in other recording?”
“I want to apply all the settings of this recording to other videos, what should I do?”
If you just encounter the similar situation above, don’t worry. FocuSee - Recording Preset feature can enable you to set a set of specific settings for quick application when recording videos. Including configuring the canvas ratio, mouse style, click effect, camera layout, watermark setting,etc. The following instructions will help you do it.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
Step 1. Edit Recording.
After you finish the recording, you will enter the editing panel bar. You can change the canvas ratio, mouse style, click effects, camera layout, etc, as you like.
Enter the Editing Panel
You can click here to learn more about how to edit recordings using FocuSee.
Step 2. Create the Preset.
After you finish editing your recording, please click Preset button in the upper right corner to create a preset.
Click the Preset Button
Then, please enter the preset template name and click Create.
Create Your Preset
Create Your Preset
After you create the template name, you will see the following page.
Rename the Preset
Rename the Preset
In this setting page, you can:
1Rename: Rename preset template.
2Set as Default Preset: The preset template will be automatically applied to new videos.
3Apply: Apply this preset template to the current recording.
4Delete: Delete the preset.
Saved presets will not be automatically updated after modification. Please create a new preset and save.
Step 3. Apply for Preset.
After creating the preset, please click Apply button to apply the preset. It will automatically apply to your next newly recorded video.
Apply for Preset
Apply for Preset
1. Presets will only apply to the attributes that are applicable to the current project. For example, if the current project does not have a camera but a preset that includes camera settings is applied, then the camera-related attributes will not be applied.
2. If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
