Free Download For Win & Mac | 100% Clean & Secure
Once your video is ready, you can download the video to your computer. Additionally, you will have access to the video file history for your convenience.
| Benefits | Free Version | Activated Version |
| Export Video | 1 (With Watermark) | Unlimited (No Watermark) |
Once the recording is done, you can click the Export button to download the video.
In this part, you can:
Export Video
You can also use shortcuts Ctrl+S for save or Shift+Ctrl+S for save as. Discover how to complete the relevant settings for keyboard shortcuts, click here for in-depth instructions.
After the export is complete, you can copy the video file to the clipboard, open its folder, or share the video directly for quick and easy file management and sharing.
Export Complete
By clicking the File button in the upper left corner of the software, you can view the video history.
View File History
The Project History records all the videos you have created. You can manage them by re-editing the video, locating the saved file on your computer, or deleting the video.
Manage the Videos
If you have a large number of project files, you can enter keywords in the search bar at the top to quickly find the project you need.
Search Project Files
If you need to delete multiple project files at once, use the Select All option to select multiple files and delete them in one go, making project management more efficient.
Delete Multiple Projects
Please click File button and select Extract source files button, you can choose to extract camera files, audio files and video files.
Extract Source Files
If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
