FocuSee Guide
Learn how to create pro screen recordings with FocuSee. Use auto-zoom and AI features like avatars and voice enhancement to easily produce engaging, polished videos. Download and try it now.
Free Download For Win & Mac | 100% Clean & Secure
View PricingView Suitable Price Plan
Basic Information
What Is FocuSee?
FocuSee is a software designed to streamline the post-production process for screen recordings, enabling users to produce visually engaging videos without the need for manual editing.
The software automatically follows cursor actions, integrates zoom-in effects, and enriches backgrounds, delivering high-quality, professional videos.
FocuSee is ideal for a variety of uses, including demos, tutorials, promotional videos, and product launches.
Select “Recover from iOS Device” Mode
Computer System Requirements
Windows OS macOS
Operating System Windows 10 or later macOS 10.15 or later, and optimal experience on macOS 12.3 and above
Processor Intel i5 and above processors, dual-core 2.9GHz and above Apple M1 or later or Intel-based Mac
Memory At least 8GB of RAM At least 8GB of RAM
How to Check Your Computer Specifications?
For Windows Computer:
Step 1. Find "Settings" option on your computer.
Step 2. Choose "System" option.
Step 3. Choose "About" option. And you will view the detailed info about computer specification.
For Mac Computer:
Step 1. Click the Apple icon on the top left of your computer screen.
Step 2. Click "About this Mac".
Step 3. You will find the computer specifications in the following appearing window.
Differences Between Free & Activated Versions, and AI Credits Calculated Rules
You can use FocuSee for free to record and edit your screen, and even export one video for free with a watermark to experience its full quality. To unlock unlimited high-quality exports (up to 4K & 60FPS) and remove all watermarks, upgrade to an activated plan. Note that some AI-powered features require additional AI credits.
Benefits Free Version Activated Version AI Credits Calculated Rules
Record Video /
Edit the Recording /
Zoom-in Effect /
3D Motion /
Motion Blur Effect /
AI Avatar 150 Credits/Minute
Remove Camera Background /
Beauty Filter /
Remove Silence & Fillers 1 Credit/Minute
Vocal Enhancement 4 Credits/Minute
AI Subtitles 1 Credit/Minute
Add Watermark /
Annotations /
Add Background Music /
Export Video 1 (With Watermark) Unlimited (No Watermark) /
Share Video /
Menu Bar Settings
After you launch FocuSee, you will see the Menu Bar Settings button in the upper right corner of the software.
Here you can unfold the Menu Bar Settings button to:
Settings: Allow you to easily perform various recording tasks, such as starting or stopping recordings, clipping videos, and adding zoom-in effects, without relying solely on mouse clicks or menu navigation.
About: Check FocuSee version.
Language: Choose your preferred language. (FocuSee currently supports 9 languages: English, French, German, Japanese, Spanish, Simplified Chinese, Traditional Chinese, Portuguese and Korean.)
Check for Updates: Check if there is a newer version of the app and upgrade FocuSee.
User Survey: A questionnaire designed to gather feedback and insights from users about the experiences with FocuSee.
Send Feedback: Share with us your thoughts, suggestions, and any issues you encounter while using FocuSee. Once we receive your feedback, we will reply you within 24 hours on workdays and 48 hours on weekends.
Guide: View the user guide to make good use of FocuSee.
FAQ: Visit the FAQ to get quick solutions.
Menu Bar Settings
Menu Bar Settings
Overview of Video Recording
1. Teleprompter
FocuSee's built-in Teleprompter helps you record with confidence by displaying your script on screen. Ideal for creators, educators, and demo makers who want to speak smoothly and naturally without missing a line.
2. Record Computer
Whether you need to capture everything or just a portion for computer screen, FocuSee lets you choose from Full Screen, Window, or Custom Area recording modes to match any scenario.
3. Record Android Phone/Tablet
Capture every moment on your Android with clarity. From mobile tutorials and gameplay to important video calls—FocuSee delivers it all.
4. Record iPhone/iPad
Records your iPhone/iPad screen. It's ideal for crafting clear tutorials, showcasing app workflows, and capturing gameplay highlights.
Recording and Teleprompter
Overview of AI Features
1. AI Avatar
With FocuSee's AI Avatar, you can generate lifelike virtual personas that present your message clearly and professionally.
2. Remove Camera Background
Remove Camera Background uses AI to easily remove your camera background. Just follow the instructions to customize your background in a few simple steps.
3. Remove Silences & Filler
FocuSee's Remove Silences & Filler feature automatically cuts unnecessary pauses and filler words, making your videos smoother, more professional, and easier to follow. Learn how to detect, remove, and fine-tune them in just a few clicks.
4. Vocal Enhancement
Vocal Enhancement feature uses AI to enrich your voice, remove harsh tones, and optimize microphone audio for a fuller, more magnetic sound—turning ordinary recordings into studio-quality audio with just one click.
5. AI Subtitles
AI Subtitles transforms microphone audio into subtitles in seconds, with flexible options for manual adjustment and optimization.
6. Beauty Filter
Beauty Filter enhances your webcam appearance with AI-powered skin smoothing and natural facial refinement, helping you look polished and camera-ready while maintaining a realistic look—all with a single click.
Overview of Adding Effects
1. Zoom-in Effect
Zoom-in Effect enlarges specific areas of the screen to draw attention, making it ideal for presentations, tutorials, or highlighting key details.
2. 3D Motion Effect
3D Motion Effect adds a sense of depth and spatial movement to your screen elements, allowing them to move naturally forward, backward, sideways, and vertically. It highlights key areas while creating a dynamic, layered presentation, making your content more engaging and intuitive for viewers.
3. Cursor Effect
Cursor Effect highlights and animates your mouse pointer in recordings, letting you customize its appearance, animations, and sounds to guide viewers’ attention precisely.
4. Blur Effect
Blur Effect lets you obscure sensitive or distracting areas in recordings, protecting private information like passwords or personal data. Learn how to apply and customize it easily.
5. Motion Blur Effect
Motion Blur Effect simulates rapid movement by blurring subjects along their motion path, enhancing speed, dynamism, and visual impact in videos or images.
6. Keyboard Shortcuts
Keyboard Shortcuts lets you show or hide keystrokes and customize their type, position, and style in your videos.
7. Spotlight Effect
Spotlight Effect lets you quickly highlight specific areas in your videos, with adjustable styles for a more professional look.
Overview of Video Editing
1. Annotations
Annotations lets you add text, shapes, arrows, highlights, and other visual elements to emphasize key points, making your tutorials, presentations, and demonstrations clearer and more engaging.
2. Recording Preset
Recording Preset lets you save and quickly apply custom settings—such as canvas ratio, mouse style, click effects, camera layout, and watermark—when recording videos.
3. Edit the Recording
Edit the Recording lets you edit your FocuSee recordings or import videos for editing, enhancing visual appeal and viewer engagement.
4. Camera Layout
Camera Layout lets you control how your camera appears and integrates with your screen recording.
5. Audio Control
Audio Control lets you enhance or mute audio after recording.
6. Add Background Music
Add Background Music lets you upload your own music or choose from built-in tracks, then trim audio, adjust volume, apply fade effects, and loop playback to create a more immersive viewing experience.
7. Captions
Captions automatically generate subtitles from your microphone audio, helping viewers follow your content more easily while improving accessibility and engagement.
8. Edit Subtitles
Edit Subtitles lets you refine captions by correcting text, adjusting timing, splitting or merging subtitle segments, and customizing styles for greater accuracy and readability.
9. Add Watermark
Custom Watermark lets you add personalized watermarks to protect your content and boost your brand image.
Overview of Saving & Sharing
1. Export the Video
Export Options let you choose the resolution and save videos locally as MP4 or GIF.
2. Share the Video
Cloud Sharing lets you upload videos and share secure, password-protected links instantly for a distraction-free viewing experience.
3. Import Video to Create Project
Import Video to Create Project lets you import existing videos into FocuSee for editing, allowing you to enhance them with effects, subtitles, annotations, background music, and other editing tools—without recording from scratch.
If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
