Free Download For Win & Mac | 100% Clean & Secure
"I want my video to automatically generate captions based on my audio. How can I do this?”
“Some words in my video's captions are wrong. How can I adjust it?”
If you come across similar situations as mentioned above, please don’t worry. FocuSee-Auto Captions function can help you enable the automatic generation and manual adjustment of the captions. You can refer to this instructions to learn how to incorporate captions into your video.
| Windows OS | macOS | |
| Operating System | Windows 10 or later | macOS 10.15 or later, and optimal experience on macOS 12.3 and above |
| Processor | Intel i5 and above processors, dual-core 2.9GHz and above | Apple M1 or later or Intel-based Mac |
| Memory | At least 8GB of RAM | At least 8GB of RAM |
Before starting the screen recording process, please enable your microphone, system audio or headphones.
Device Setup
After the video recording is completed, please click Captions in the left menu.
Click Captions
Within this tab, you will find 3 auto caption generation modes: Nano, Basic, and Pro. Each mode offers varying levels of accuracy in caption generation.
Choose a Model
Discover how to record videos using FocuSee. Click here for in-depth instructions.
Please select either the Auto option or a specific language from the Language section.
Choose a Language
Then click the Generate Captions.
Click the Generate Captions
And the captions will be generated automatically. You can adjust the captions on the left side.
Adjust the Captions
You also can select the Style icon to customize the font size, position, and spacing of the captions.
Select the Style
If you need to regenerate captions, please click the Back button.
Click Back Button
Then you will see the following page.
Export Captions
In this page, you can:
After you finish the captions, please click Export button to export the video.
Click Export Button
If you have further question after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how FocuSee is working for you.
If you're enjoying FocuSee, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover FocuSee and motivates our team!
