Need a screen recorder that automatically zooms into clicks, follows your cursor, and makes tutorials easier to watch? We tested 8 tools for demos, tutorial videos, and walkthrough videos. FocuSee is best for all-in-one editing, Cursorful is best for browser recording, and Recordly is currently the best free option.
A screen recorder with auto zoom allows you to capture your screen while magnifying significant movements you make. For instance, the tool enlarges the area you’re working on whenever you press a button, drag the mouse, or type something. It makes it easier for viewers to understand the instructions. It is very useful for tutorials, training videos, and online lessons. You don’t need to edit or zoom the video later. It saves time and makes your video look more professional. Some tools also let you easily adjust the zoom size, speed, and focus area.
| Platform | Auto Zoom Type | Built-in Editing | Best For | Pricing | |
| FocuSee | Windows & macOS | Auto clicks, typing & actions | Advanced | Tutorials & product demos | Free trial /$19/mo |
| Cursorful | Browser | Cursor-follow zoom | Basic | Browser tutorials | Free / $99 one-time |
| Screen Studio | macOS | Auto + manual zoom | Moderate | Mac creators | $29/mo or $229 once |
| Rapidemo | Windows | Smart zoom | Basic | Product demos | $19/mo or $179 once |
| Recordly | Web-based | Automatic zoom | Basic | Free recordings | Free |
| AutoZoom | Web/Desktop | AI auto zoom | Basic | Fast workflows | Custom pricing |
| Cap | Windows & macOS | Limited zoom | Basic | Lightweight recording | Free |
Let’s discover the 7 best screen recorders with the Auto Zoom feature:
Best For: Tutorial creators, SaaS demos, and onboarding videos
Screen Recorder with Auto Zoom – FocuSee
FocuSee is one of the best screen recorders with auto zoom. It helps you create amazing videos easily by recording your screen, face, and voice simultaneously. You don’t need to do any editing because FocuSee does it automatically for you. It adds auto-zoom to focus on your mouse and actions, capturing the mouse cursor in recording to make everything clear. You can also use a mouse highlighter, automatic captions, and keyboard shortcut display to improve your videos.
FocuSee lets you choose from layouts, cursor click effects and styles, and zoom effects. You can trim, cut, or change the video speed to make it short and simple. Add your watermark to protect your content. You can also use motion blur, filters, and frames to give your videos a nice look. With a built-in teleprompter, you can read your script while recording. It also supports mic and system sound recording on different tracks. Finally, export your videos as high-quality videos or GIFs.
Key Features:
Pros
Cons: Less suitable for advanced timeline editing
Check out the simple steps below to use this software to zoom in on the video:
Step 1. Go to the official website and free download FocuSee and open it. From the options on the main screen, select your camera, mic, and speaker.
Choose the Recording Model
Step 2. Choose what you want to record—your whole screen, a specific window, or just part of it.
Step 3. Check if your camera and audio are working properly. Then press the red “Record” button. After a 3-second countdown, the recording starts. Click the red “Stop” button when you’re done.
Step 4. Your video will be shown with automatic zoom and effects.
Automatic Zoom Effects
You can cut zoom sections, adjust playback speed, or highlight key moments. In addition, you can manually select the parts of your video that you want to zoom in on or out of.
FocuSee Zoom Settings
You can also customize the cursor size, style, and click effects to match your needs. This makes your actions clearer to viewers, helps guide their attention, and creates a more polished and engaging video.
Change the Cursor Settings
Step 5. Click “Export” to save your video as an MP4 or a GIF file. Or share your video via a link.
Export Your Video
Watch this sample video I created in FocuSee with the automatic zoom-in effect:
Best For: Users searching for “screen recorder that follows cursor” or browser tutorial creators
Cursorful is a smart screen recorder that adds auto-zoom and smooth-panning effects during recording. It works as a Chrome extension and is easy to use—no sign-up needed. It follows your mouse clicks and movements, making your cursor the focal point to guide your viewers. You can also edit the zoom level, position, and timing using its built-in editor.
With 4K export support in the Pro plan, you get sharp, high-quality videos. It uses Chrome, Edge, or Brave browsers to work on Windows, macOS, and Linux.
Screen Recorders with Auto Zoom – Cursorful
Key Features:
Pricing Plan:
Pros
Cons
Best For: Mac users creating premium tutorials and product demos
Screen Studio
Screen Studio is a powerful macOS screen recorder that lets you produce high-definition videos quickly. Auto zoom highlights your actions on your screen, keeping your viewers easily engaged throughout your recordings. Manual zoom lets you zoom in on specific screen portions as you record.
Screen Studio captures in 4K, giving you clear, high-quality videos. You get precise movements of the mouse cursor with no bumps in the animation and the ability to change the cursor size after the recording. It also lets you capture the sounds of your computer, voice, and webcam, making it perfect for in-depth how-to videos. You can easily edit your videos using the convenient editing tools.
Key Features:
Pricing Plan:
Pros
Cons
Best For: Users searching for screen recording for demos
Screen Recorders with Auto Zoom – Rapidemo
Rapidemo is a straightforward and effective screen recording tool to help your videos look professional. You can use smart zoom to ensure only the key details get shown when you’re recording. It allows your audience to keep track of the action displayed on-screen. Recording with Rapidemo is possible up to 4K resolution, providing stunningly clear videos. Recording screen, webcam, and audio allow you to create presentations and tutorials.
Key Features:
Pricing Plan:
Pros
Cons
Best For: Users searching for free auto zoom screen recorders
Auto Zoom Screen Recorder – Recordly
Recordly is a strong choice for users who want free screen recording with automatic zoom functionality. It focuses on simplicity and fast sharing rather than advanced editing.
Users can quickly record tutorials, demos, and presentations without paying upfront. This makes it attractive for startups, freelancers, and creators testing auto zoom workflows for the first time.
Key Features
Pros
Cons
Pricing: Free
Best For: Users who want fully automated zoom workflows
Auto Zoom Screen Recorder – AutoZoom
AutoZoom focuses heavily on automation. It is built for users who want zoom effects to happen automatically without manually adjusting timelines.
The tool is useful for creators who prioritize speed and want an AI-driven workflow for tutorial recording. It removes much of the manual editing typically required in traditional video software.
Because it is newer, it may not offer as many advanced features as larger competitors.
Key Features
Pros
Cons
Pricing
Best For: Budget-conscious users and simple recording needs
Auto Zoom Screen Recorder – Cap
Cap is a lightweight alternative for users who want fast recordings and easy sharing without paying for premium tools. While its auto zoom capabilities are not as advanced as dedicated tools, it remains a useful option for simple recordings.
Its open-source approach makes it appealing to developers, startups, and users looking for affordable Loom alternatives.
Key Features
Pros
Cons
Pricing: Free
If you’re looking for a free auto zoom screen recorder, these tools offer basic zoom effects without expensive subscriptions.
If your main goal is keeping viewers focused on mouse movements, these tools offer strong cursor-follow tracking.
These tools are better suited for SaaS demos, product walkthroughs, onboarding videos, and feature announcements.
What is an auto zoom screen recorder?
An auto zoom screen recorder automatically zooms into your cursor movements, clicks, typing actions, or selected areas while recording. It helps viewers focus on important on-screen actions without requiring manual zoom editing later.
Which screen recorder is best for automatic zoom?
FocuSee is one of the best all-in-one options for tutorials and product walkthroughs because it combines auto zoom, cursor effects, subtitles, and editing tools. Cursorful is a better option if you prefer browser-based recording.
Are auto zoom screen recorders available for both Windows and Mac?
Yes. FocuSee works on both Windows and macOS, while Cursorful works through Chrome-based browsers. Screen Studio is currently Mac-only.
What’s the best free auto zoom screen recorder?
Recordly, Reqord, and Cursorful all offer free options for users who want basic automatic zoom features.
Can I manually adjust zoom after recording?
Yes. Some tools like FocuSee and Screen Studio allow users to manually adjust zoom timing and focus areas after recording.
Does OBS support automatic zoom?
OBS Studio does not offer built-in automatic zoom features. You would typically need plugins or manual editing to create zoom effects.
What’s the difference between auto zoom and cursor follow?
Auto zoom typically detects clicks, typing, or important actions and zooms in automatically. Cursor-follow tools continuously track your mouse movement throughout the recording. Tools like Cursorful specialize in cursor-follow recording.
Which tool is best for product demo videos?
FocuSee and Rapidemo are strong choices for SaaS demos, onboarding videos, and product walkthroughs because they simplify zoom effects and reduce editing time.
Auto-zoom screen recorders make your videos clearer by automatically focusing on important parts. They help viewers see exactly where the action is, without needing extra editing. Many tools support high-quality recording up to 4K resolution, making your videos sharp and professional. These recorders are compatible with various devices and often include additional features such as manual zoom adjustment, editing, and captioning. FocuSee is a fantastic option if you’re looking for a robust and user-friendly screen recorder. To quickly and easily create flawless videos, it provides automatic zoom, basic video editing, and a variety of export possibilities.
