Steps to Zoom in on a Video Easily
1
Record a Video
Create a video that needs to be zoomed in by recording your screen and camera.
step-arrow
2
Automatically Zoom Your Video
FocuSee automatically zooms in on the location of the mouse click or you can change the zoom-in part manually.
step-arrow
3
Export and Share
You can export the video as an MP4 or GIF file and share it in a way you like.
Why Use This Video Zoomer?
Automatically Zoom the Screen
During the screen recording process, FocuSee automatically zooms in on the location of the mouse click, helping you highlight the clicked area. This allows you to focus solely on the main operation, while the final result fully demonstrates the process of using the product.
Zoom in on a Video
Change the Zoom Option
You can modify the size of the zoomed screen (from 1.0x to 4.0x). Additionally, you have the option to decide whether to enable the zoom-in effect for each clip and manually select the portion of the video that you want to zoom in on.
Zoom in on a Video
Apply to All Video Zooms with One-click
Apply the current zoom settings to all zoom screens within the current video with just one click. Alternatively, you can choose whether to enable the zoom effect for individual clips. It's an almost automatic video editing process!
Zoom in on a Video
More Video Editing Tools
FAQs About Video Zoom Editor
1. What is a video zoom editor?
A video zoom editor helps you zoom in on specific parts of a video to highlight details. With FocuSee, zoom can be created automatically during screen recording based on where you click, and you can adjust or fine-tune the zoom afterward.
2. How does auto-zoom work in FocuSee?
3. Can I change the zoom level (for example, 1x to 4x)?
4. Can I choose where to zoom in manually?
5. Can I turn the zoom effect on or off for specific clips?
6. Can I apply the same zoom settings to the whole video?
7. What types of videos is auto-zoom best for?
8. What export formats are supported?
9. Which platforms does FocuSee support?
FocuSee
Video Zoom Editor
Automatically zoom in on the actions you perform on the screen, such as clicking a button, allowing you to fully display specific details and attract more attention.
Zoom in on a Video
