Are there any macro recorders that record mouse and keyboard position?
— A Reddit User from r/software
The idea of tracking and recording mouse movements is in increasing demand nowadays. Recording mouse movements and clicks proves particularly valuable when you make product demos, tutorials, and other presentation screen records. It can also provide a more in-depth look at how you engage in your activity, such as recording mouse movement when you are playing a computer game and demonstrating your newly developed products. To assist you, this post will provide 4 convenient methods and several tools to record mouse movements on your Windows and Mac.
Proven Ways to Record Mouse Movement
Yes, you can record mouse movements. Most screen recording software includes options to capture the cursor and its movements during a screen recording session. Some software even allows for highlighting clicks, changing the cursor’s appearance for better visibility, and emphasizing mouse paths to make the movements clearer to viewers. To record mouse movements, ensure that the option is enabled in your screen recording tool before starting your recording session.
To get started, let’s explore 4 proven methods to capture and record mouse movements.
As a professional screen recorder, FocuSee is a good choice for recording mouse movements. Compared with other mouse movement recorders, it excels in capturing mouse movements, clicks, scroll wheel actions, keyboard input, and other on-screen activities. Notably, it can zoom in on a recorded file easily to enhance the visibility of your mouse click actions during your recording. In addition to recording mouse movements and clicks, you are also encouraged to enhance your recordings by incorporating mouse cursor effects, mouse cursor click sounds, animation effects, spotlight effects, and zoom effects during the post-recording editing process.
FocuSee Key Features
Here is stepwise guidance on how to record mouse movements via FocuSee:
Step 1. Free install FocuSee and open it on your computer. Choose a recording mode to get started. Here, we take Custom mode for example.
Choose a Recording Mode
Step 2. Frame the area where you want to record, and click on the REC button to initiate the recording process.
Frame an Area to Record
Step 3. When you finish recording the mouse movement and click, tap on the red Stop icon on the toolbar.
Choose and Preview the Mouse Cursor Effect
You can adjust the style, size, and click effect of the mouse cursor, add a spotlight, change the zoom effect, and more.
Change the Cursor Settings
Step 4. Click “Export” to save your video as an MP4 or a GIF file.
Export Your Video
A Macro Record button on your mouse will allow you to record macros without interrupting your current application or game. Let’s have a look at how to record mouse movement via the Macro Record button:
Step 1. Launch the program or game where the macro will be recorded.
Step 2. Click the macro record button to start recording mouse actions. The flashing light on the macro record button will become constant. The mouse’s display screen will show the press target mouse button icon.
Press The Macro Record Button
Step 3. To designate a macro for a specific mouse button, click that. The light next to Macro Record will flash. The mouse’s digital screen will show the recording symbol.
Step 4. Record your activities. The Macro Recorder will record any time a key is pressed, a mouse is clicked, or a period of inactivity occurs. Moving the mouse or pressing a reassignable key will not be recorded. When recording a macro, the button blinks.
Step 5. Just hit the Macro Record button once again after you’re done with the recording. After the macro has been successfully recorded, the Macro Record button and display will switch off.
The Xbox Game Bar is a screen recorder that may be used to capture gameplay. One of the best parts about this program is that it is pre-installed software. It can record mouse movements in Windows 10. However, it’s not as flexible as other screen recording programs regarding post-recording editing. By following the instructions below, you may easily record your mouse clicks on the screen with this free program.
The step-by-step guide to using Game Bar to Record Mouse Actions:
Step 1. Press the Windows key + G to open the program using its standard shortcut.
Press Windows and G Button Together
Step 2. Next, the Game Bar’s home screen appears. To begin recording, press the red circle in the center. When you’re through recording, click “Stop,” and your computer will store a record file of your mouse cursor moving across the screen.
Tips for Some handy shortcuts:
QuickTime Player is an essential tool for Mac users. It is capable of recorded files and multimedia applications. This program enables the recording of the screen together with external sounds captured through a microphone. Additionally, the addition of a webcam enables you to create a facecam recording quickly. When you choose it, recording the mouse click is also a simple process.
Here are steps to record your mouse movements on a Mac:
Step 1. Launch your QuickTime Player application. Then, to make a new recording file, go to the “File” menu and choose “New Screen Recording.”
Select New Screen Recording
Step 2. To configure the QuickTime Player, choose “Open System Preferences” from the menu.
Step 3. Once complete, the record windows appear on the main screen’s bottom. To begin recording your mouse movements on the screen, click the “Record” button. In addition to that, you have the option to either record the whole screen or just a certain portion of it.
Step 4. When ready to complete the recording, click the Stop button to end the recording session and save the file to your device.
Having learned 4 useful methods to record mouse movement on Windows and Mac, we’ll introduce another 4 mouse recorders to record the trajectory and actions of the mouse, rather than recording the content of the screen.
MouseKey Recorder is a simple but effective automation tool that records mouse and keyboard activity. Record tasks that are performed repeatedly and automate all PC functions. The scheduling feature allows you to store an endless number of macros, which may be played back at any time and at whatever pace you want (original or double, triple). After you’ve downloaded and installed the software on your computer, a window will show you all it can accomplish. With a single click of the RECORD button, you may begin recording all mouse and keyboard activity.
Mouse Movement Recorder – MouseKey Recorder
Key Features:
Limitation:
If you are looking for an excellent piece of software to automate the process, look no further than Macro Toolworks. A freeware version is also available to record and play back mouse movements. This may help you save a lot of time by eliminating the need to repeatedly type the same information into documents, emails, and other messages. If you can automate a process, you’ll have more time to focus on what matters. Click the “Add” button, label your new macro, and choose its target action to create a new one.
Mouse Movement Recorder – Macro Toolworks
Key Features:
Limitation:
The Mouse and Keyboard Recorder is a tool that can record all your mouse and keyboard operations and correctly replay all those events with 100% accuracy. Free Mouse and Keyboard Recorder is a simple piece of software that, once installed, enables the user to record mouse and keyboard clicks and movements. It captures all mouse and keyboard operations and repeats them properly, enables setting repeat times and the delay between two repeatings, supports adjusting repeat speed, and comes with a Mouse Record and a Mouse Clicker.
Mouse Movement Recorder – Mouse and Keyboard Recorder
Key Features:
Limitation:
Mouse Recorder Pro 2 is freeware for automating repetitive chores. Mouse Recorder Pro gives you the ability to play back the steps that were captured while you were installing or working with a certain program. It also allows you to modify your recordings and choose the amount of time they repeat. It is helpful if you aim to produce smooth screencast lessons since it may assist in simplifying edgy mouse motions as well as improve time.
Mouse Movement Recorder – Mouse Recorder Pro 2
Key Features:
Limitation:
What is a Mouse Record?
A mouse record means capturing or recording mouse movements, clicks, and scrolls on the screen so they can be replayed later.
It’s often used in:
How to record mouse clicks and repeat?
You can easily record your mouse clicks and repeat with FocuSee – a powerful screen recorder with auto zoom and mouse tracker. After recording, you can customize your mouse appearance:
What’s the difference between recording for video and for automation?
Video recording (e.g., FocuSee) creates a video showing your mouse activity for tutorials or presentations. Automation recording (e.g., TinyTask) replays your mouse actions to perform the same tasks automatically.
In conclusion, this article mentioned 4 easy methods to record mouse movements on Windows and Mac, as well as 4 mouse recorders. If you want to highlight your mouse movement on the screen, FocuSee stands out for its easy steps and powerful functions. Except for an automatic zoom-in feature, this tool also allows adding animation effects, mouse cursor clicks sound, etc. Free download FocuSee and try it now!
