When people watch a tutorial or demo, they don’t just want to see the screen; they want to understand every step without guessing. That’s why showing your mouse clicks can make such a big difference. It guides the viewer’s eyes and makes learning easier.
A screen recorder with mouse click effect is the perfect tool for this. It highlights each click so your audience can follow along effortlessly. In this article, we’ll go through five of the best options to help you create clear, engaging videos.
When you record your screen, your mouse works like a guide for viewers. But without any effects, it’s easy for people to miss where you clicked or what part of the screen you want them to focus on. Because of this, mouse click effects are particularly useful because they highlight each click.
What is Mouse Click Effect
Every mouse click can create a spotlight, ripple motion, glowing circle, or even a tiny sound. These effects keep your audience interested and make it easy for them to follow up, which makes them very useful for online classes, tutorials, and demos.
| FocuSee | OBS Studio | Bandicam | MiniTool Video Converter | Camtasia | |
| Adjustable cursor | ✔️ | Only via plugins | ✔️ | ✔️ | ✔️ |
| Left/Right click | ✔️ | Only via plugins | ✔️ | ✔️ | ✔️ |
| Click sound effect | ✔️ | ✔️ | ✔️ | ✔️ | ✔️ |
| Hotkey shortcuts | ✔️ | ✔️ | ✔️ | ✔️ | ✔️ |
| Export options | MP4&GIF | MP4 | MP4/AVI | MP4/others | MP4, GIF, others |
| Compatibility | Windows, macOS | Windows, macOS, Linux | Windows only | Windows only | Windows, macOS |
More than simply a screen capture tool, FocuSee is made to make your videos simple to see and comprehend. While you’re recording a tutorial, product demo, or online lesson, it gives you the ability to highlight important parts of your screen using basic editing tools like zoom, spotlight, and cropping.
The Cursor Settings tool is one that truly makes a difference. Because the mouse guides your viewers, FocuSee allows you to make it always obvious. You may add click effects, alter the appearance, modify the size, or even make a sound when you click. In this manner, your audience will always be aware of what you are doing.
Screen Recorders with Mouse Click Effect – FocuSee
Key Features
Pros:
Cons:
How to record your screen with Mouse Click Effect
Step 1. Free download FocuSee and open it on your computer.
Choose the Recording Mode
Step 2. Record your screen, or you can just upload a video file from your computer. After recording, go to the editing interface in FocuSee.
Editing Interface in FocuSee
Step 3. Make it easier to view by adjusting the cursor’s size. Select a cursor design that complements your movie.
Adjust the Cursor Size and Style
Step 4. Add click effects or sounds, and apply the spotlight effect if needed.
Add Click Effects and Sound Effects
Step 5. Export your final video.
Export Your Video
OBS Studio is a free tool for streaming live and screen recording. It is compatible with Linux, Mac, and Windows. It is used for lessons, online classes, and gaming. You may continuously record your screen, camera, and sound with OBS.
You may also add text, images, or overlays, adjust your music, and change between several layouts (referred to as scenes). Even streaming straight to Twitch or YouTube is an option.
Key Features:
Pros:
Cons:
How to record the screen with mouse effects in OBS
Step 1: Download and install OBS Studio.
Step 2: Add a Display Capture to record your screen.
Step 3: To show mouse clicks, add a cursor effect plugin or overlay (like a highlight).
Add a Cursor Effect Plugin
Step 4: Place and size it to match your mouse.
Step 5: Click Start Recording.
Bandicam is a straightforward Windows screen recorder that enables you to capture your screen, games, and even gadgets like consoles and cameras. It provides you with videos of excellent quality at a small file size. You may also add mouse effects, record your voice, and draw on the screen in addition to these functions.
Bandicam is a wonderful tool for tutorials, presentations, online courses, and gaming videos because of. It requires no extra devices to produce amazing effects and is simple to use.
Key Features:
Pros:
Cons:
How to record the screen with mouse effects with Bandicam
Step 1: Install and open Bandicam.
Step 2: Choose the Screen Recording settings.
Step 3: In settings, turn on Mouse Effects (highlight and click sounds).
Turn on Mouse Effects
Step 4: Select the area you want to record.
Step 5: Press REC to start and stop when done.
MiniTool Video Converter 4.3 is a handy tool that helps you with all your video needs. You may download from social media, reduce enormous files without reducing quality, record your screen in 4K, and convert videos into several formats.
It has no limits or watermarks, is safe, and is free to use. Anyone can use it because of its simple and clean design, regardless of whether they want to generate material for internet sharing or simply preserve videos.
Key Features:
Pros:
Cons:
How to Record Screen with Mouse Clicks in MiniTool
Step 1: Click Screen Record, open the three-line menu, and go to Settings.
Go to Settings
Step 2: Choose where to save your video and set video options. Tick Show mouse cursor, turn on mouse clicks and highlights, and pick the color and size. Click OK.
Turn on Mouse Clicks and Highlights
Step 3: Select the area you want to record.
Step 4: By default, it records the Full Screen, but you can also pick a region. Turn your system audio or microphone on/off, then press the Play button or hit F6 to start recording.
Camtasia offers a built-in screen capture tool and a built-in video editor. Screen, camera, and audio may all be recorded simultaneously, and they can all be edited using the same program. It’s ideal for presentations, classes, and tutorials.
You may use basic drag and drop tools to add text, arrows, highlights, and even subtitles. Further, it features AI technologies that make it much easier to create videos by helping you quickly produce voice-overs or screenplays.
Key Features:
Pros:
Cons:
How to Show Mouse Clicks with Camtasia:
Step 1: Open Camtasia and start a new recording.
Step 2: Select screen, webcam, or audio, then hit Record.
Step 3: Stop recording when done, and it opens in the editor.
Step 4: Go to Cursor Effects on the left panel.
Click Cursor Effects
Step 5: Drag a click effect (like highlight or circle) onto your video.
Drag a Click Effect Onto Your Video
Step 6: Preview, then save or export your video.
What are the Benefits of Using a Screen Recorder with Mouse Click Effect?
It helps to clarify your recordings by displaying the exact place of your clicks. This makes it very easy for the audience to follow along, which is great for product demos, training films, and tutorials.
When recording, how can I bring my mouse cursor into focus?
The majority of screen recorders provide a cursor effect setting. To make it simpler for viewers to see your cursor, you may activate the option that surrounds it with a glow, circle, or spotlight.
What is the ideal video format for taking screenshots?
MP4 is the best choice. It keeps the video clear, makes the file size smaller, and works on almost all devices and platforms without any issues.
For anybody making lectures, tutorials, or guides, a screen recorder with a mouse click effect is essential. Viewers can more easily follow your movements and comprehend each stage with the help of these tools.
Although there are other methods for recording screens with mouse effects, FocuSee stands out due to its advanced cursor settings and easy-to-use interface. FocuSee is worth a try if you want professional-quality, clear movies without having to put in extra work.
