TL;DR:
FaceTime screen recordings may lack sound due to settings or permissions. Fix by enabling the microphone, updating software, or using third-party recorders like Record It (iOS), FocuSee (Mac/PC), or DU Recorder (Android). Always get consent before recording.
FaceTime is one of the most popular messaging apps in the world, with hundreds of millions of users relying on it daily for private and business communications. While this is an Apple-only app that doesn’t work on PC or Android, it’s so beloved by iPhone, iPad, and Mac owners that ‘face-timing’ is widely used as a verb. This level of acceptance wouldn’t be possible if the app malfunctioned frequently, but like with any other software, there are occasional bugs that can spoil the user experience.
FaceTime screen recording function is an essential part of the package, so it’s very annoying when the sound is not being captured. This problem can usually be solved quickly, but in some cases, you might need to switch to a different screen recorder. This article will provide you with savvy hints that will teach you how to fix FaceTime screen recording with no sound issues with a minimum of lost time.
Why Does FaceTime Screen Recording Have No Sound?
Can anyone let me know if there is a way to recover sound from a screen recording Facetime? I screen recording the facetime and didn’t know the sound wouldn’t be there 🙁 would love to recover the sound as its very sentimental!
——Tight_Inevitable766 from Reddit
In some instances, recorded FaceTime calls lack any audio, which renders them useless. There are several potential causes, so it may not be easy to determine what happened with the sound. You might have to conduct a little investigation and check the settings on your device as well as the FaceTime app. In most cases, you should be able to quickly find out what went wrong and get a pretty good idea of how to fix it. Here are some common causes of audio issues in FaceTime:
FaceTime Interface
FaceTime Interface
How to Fix FaceTime Screen Recording No Sound?
Most of the scenarios described above are easily resolved by removing the factor that was preventing FaceTime from recording sound, i.e. granting access to the microphone or installing an update.
If none of the listed reasons for audio failure apply, finding a systemic fix can be challenging. However, there’s no need for despair as there are several alternative solutions to achieve high-quality audio recording. The optimal approach is to utilize a different screen recorder that operates in the background during FaceTime conversations. Below are two methods tailored for mobile and desktop users, respectively.
How to Record Facetime with Audio on iPhone/iPad –Record It
While there is no shortage of screen recording apps that work on iOS devices, Record It is widely regarded as one of the most flexible and user-friendly options. With this app, you can record the content of your screen while you are interacting with any apps or games, including FaceTime. Thanks to the ability to add comments to the recording, this could be even better than using the native recording function in FaceTime, especially if you are having trouble with audio. It can also help you fix the iPhone screen recording no sound issue.
Here is the sequence of steps you must take to capture a FaceTime conversation with the Record It app:
Step 1. Install Record It on your iPhone or iPad and run it
Install Record It
Install Record It
Step 2. Select the option to record the entire screen and make sure the audio recording is turned on
Step 3. Start recording, then switch to FaceTime and start your video conversation
Step 4. Edit your recording with the built-in editor before saving it to your phone
How to Record FaceTime with Audio on Mac & Windows
If you are using a computer to chat with friends and associates through FaceTime, you could use FocuSee to capture those conversations with clear audio. This professional screen and audio recording software is very intuitive to use and allows for effortless creation of videos based on your screen activity. You can also record directly from a selected window or include the webcam feed into your video.
FocuSee boasts several notable features, including:
To record your conversation in FaceTime using FocuSee, just take the following steps.
Step 1. Free download FocuSee and launch FocuSee on the computer > Enter your account and password to log in to FocuSee. If you are the first time using FocuSee, just feel free to create an account.
Step 2. You can choose the one recording mode you want to record. And set up your camera and microphone.
Choose the Recording Model
Step 3. After choosing the recording mode, please just focus on your screen recordings. Let FocuSee handle the post-production automatically. You can get a visually appealing video as soon as you finish recording. After recording, you can change the background, adjust the cursor style, add captions and more.
Edit the Video with Auto Effects
Step 4. Then, export your recordings as an MP4 or GIF file or share it with a link easily.
How to Export the Video
How to Record Facetime with Audio on Android Device
While Android users cannot initiate Facetime calls directly, they now can join FaceTime sessions by clicking on a provided link and recording FaceTime calls. iOS users can send invitation links from either a desktop or mobile device, and Android users can join FaceTime calls using Google Chrome.
To record FaceTime with audio on Android devices, you can follow these steps:
Step 1. Receive a FaceTime invitation link from an iOS user via email or text message.
Step 2. Open the link in Google Chrome on your Android device to join the FaceTime call.
Step 3. Install a screen recording app from the Google Play Store, such as DU Recorder.
DU Screen Recorder Interface
Step 4. Start the screen recording app and enable audio recording before joining the FaceTime call.
Step 5. Place your Android device close to the audio source to capture clear audio during the call.
Step 6. Initiate the recording before starting the FaceTime call to capture the entire conversation.
Step 7. Stop the recording once the call is finished.
Step 8. Access, review, and edit the recorded file as needed.
Data protection policies for FaceTime recording differ by location. Call recording laws fall into one-party consent (one party informed) or all-party consent (all must agree). It’s advisable to inform all parties before recording any call.
Frequently Asked Questions about Fixing Sound in FaceTime
Why is FaceTime not recording sound when other apps are able to capture the microphone feed?
This can occur whenever some type of incompatibility prevents FaceTime app from communicating with the microphone or sound card. Some of the reasons for the failure may be trivial (i.e. wrong settings) and can be fixed very quickly without professional help.
Why FaceTime work normally on my iPhone but won’t record sound on my Mac?
If you are having trouble with recording sound with FaceTime only on one device, it’s wise to check your security settings and audio input sources. Updating your OS could also resolve the issue, and only if the problem persists should you consider using an alternative screen recorder.
Can I access the audio from a past FaceTime conversation if it hasn’t been recorded?
Unfortunately, conversations that hadn’t been recorded are not saved anywhere so if your recording doesn’t include audio it might be lost forever. The only chance to get it back is to ask the other person in the conversation to share their version of the recording (if it exists).
Final Words
Nobody likes to deal with technical issues when attempting to chat with friends or colleagues, so FaceTime problems with sound can be quite irritating. Since frustration and impulsive action won’t help, it’s better to keep a cool head and try and ascertain why the problem occurred in the first place. If you manage to do that, chances are the solution will emerge spontaneously. Even if you can’t get to the bottom of the issue, you still have the option to turn on a third-party screen recording tool and capture the conversation with high quality video and audio.
Olivia Bennett
