If you’re aiming to showcase your gaming prowess or share your commentary but are facing an “encoding overloaded” error in OBS Studio, you’re not the only one—it’s a common challenge for streamers. Fortunately, with some adjustments and optimizations, you can quickly get back to a smooth streaming experience.
This guide will explain the reasons behind the OBS encoding overload and offer you practical solutions to restore the stability of your stream, eliminate lag, and keep your audience hooked.
Streaming appears to be as easy as pressing “Start Streaming,” but in reality, your computer is tirelessly encoding your game, webcam, and audio in real time. This encoding task is resource-intensive, particularly for your CPU.
OBS Studio Interface
Here are the main factors that can trigger an OBS encoding overload:
If you’re dealing with an “encoding overloaded” issue in OBS, here are some practical steps to troubleshoot and fix the problem:
Before making any changes, it’s a good idea to test your stream to see how your system performs with the current settings. This will help you gauge the impact of any adjustments you make.
Use an online bitrate calculator to find the optimal bitrate based on your internet upload speed and desired stream quality.
If overload persists, gradually decrease the bitrate in OBS until you find a setting that works without overloading your system.
If bitrate adjustments aren’t enough, consider reducing your stream’s resolution or frame rate. While this may affect the quality, a smooth stream is often more important than a high-res, laggy one.
If your streaming resolution is lower than your recording resolution, enable “Downscale Output” in OBS to ease the load on your encoder.
Setup OBS
Free up system resources by closing background applications that aren’t needed for streaming or gaming.
If you’ve tried all the above and still face issues, it might be time to look at upgrading your hardware:
FocuSee, as the highly recommended OBS Studio alternative, is a professional screen recording software that aims to improve your focus and productivity. It is designed to help you stay focused on your screen recording tasks and minimize distractions. It is perfectly tailored to meet your needs for recording tutorial videos, product demos, promo videos, and more.
Screen Recording Editing Interface
Key Features:
Pros
Cons
Encountering the dreaded “encoding overloaded” message in OBS doesn’t have to be a stream-ending disaster. By understanding the factors that cause it and implementing the solutions outlined in this guide, you can optimize your streaming setup for a smoother, lag-free experience.
Remember to test your settings after each adjustment, and don’t be afraid to experiment to find the perfect balance for your hardware and internet connection. With a bit of patience and fine-tuning, you’ll be back to sharing your content with the world in no time!
Q: What is a good bitrate for OBS?
A: There’s no single “best” bitrate. It depends on your internet upload speed and the resolution/frame rate you’re streaming at. Use an online bitrate calculator and aim for a bitrate that’s about 80% of your maximum upload speed.
Q: Should I use x264 or NVENC?
A: If you have a powerful multi-core CPU, x264 (software encoding) can provide excellent quality. If you have a dedicated NVIDIA graphics card, NVENC (GPU encoding) is generally more efficient and puts less load on your CPU.
Q: How do I check my CPU usage while streaming?
