Suppose you created a wonderful SaaS product, and when people see it, they do not quite understand. You find your demo video too lengthy, confusing, or fails to bring out the product from the right perspective. It is not an unusual difficulty to deal with — most teams find it challenging to film demo videos that narrate the product and struggle to maintain engaging content. Even an amazing product will drive people away just because of a bad demo.
The good news is that, with the right plan and tools, you can create a demo video that grabs attention and builds trust. This guide shows you how to do it step by step. So, let’s begin!
Screen recording is not the only thing you can use to create a high-quality SaaS demo video. In order to fully engage with your audience and achieve results, your video must be clear, visually appealing, and have a purpose. The following are the main factors that convert a simple demo into the best SaaS product demo video.
Before recording, figure out who your viewers are. Understanding your audience helps shape the message, tone, and aspects displayed in your demonstration. This can make your video much more effective and relatable, whether you are a creator, marketer, or owner of a small business. Demonstrating how your product will address their problem will help you significantly.
Plan your video before recording. The storyboard or outline helps you stay on track. It ensures that the interactive product video is smooth and does not focus on minor aspects at the expense of missing major features. Planning would save your time and allow you to prioritize only what must be shown to your audience.
Having aesthetic value is very important in retaining the viewer’s attention. Record properly on the screen, provide steady transitions, and include useful accents such as zoom or focus effects. Proper visuals help explain difficult concepts more effectively and keep viewers engaged until the very end.
Rather than listing its features, it should present a small narrative about a person having an issue and how your product can address it. Such a narrative method is more exciting and user-friendly than the traditional ones. It also avoids making the content sound technical or dry.
After watching, you should clearly tell viewers what to do. Ensure that you conclude your demonstration with a clear and compelling call to action, such as registering for a test, scheduling a demo, or visiting your website. A CTA not only gives your video a reason but also converts interest into action, enabling you to lead viewers further along the sales funnel.
Making a video demo of your SaaS product that is impactful involves more than just pushing the “record” button. Most producers go for screen recordings with voiceovers, step-by-step demos, or live product usage in combination with animated overlays. Others add even more, for instance, they put subtitles, cursor effects, and smooth transitions to make the video clearer and more interesting. However, the manual process of doing all these tasks can be time-consuming and technically challenging.
Here comes FocuSee—a brilliant, multifunctional screen recording gadget that is made for easy product demo creation. You might be implementing a new feature or discussing a complicated workflow; FocuSee makes it easy with strong automation and simple editing.
Key Features:
Steps to Create the Best SaaS Product Demo Video:
Step 1. Launch the FocuSee app. By clicking on the “Camera” icon, you can decide to turn your webcam on or off. In case you want to use the script as a guide during recording, click the “Teleprompter” icon.
Use the Teleprompter
Step 2. FocuSee offers three options, namely: Full Screen, Custom, and Window. Select one that best describes your need, and click on the corresponding icon.
Recording Modes
Step 3. After you have got your settings ready, press the red REC button to record. Check whether your audio and camera are working properly.
Click the Record Button
Step 4. Upon completion, FocuSee would have also included zoom effects to draw attention to your actions on the screen. You can trim parts, adjust speed, and enhance mouse movements using animations or cursor resizing.
Edit the Demo
If the screen recording involves sensitive information such as login details, it is recommended to use the blur feature to ensure personal privacy and security. To apply a mosaic effect to your video, hit the Blur button that is located under the video preview.
Blur Effect
Step 5. When everything looks good, click the “Share” button, customize the resolution and Frame rate, and then choose “Upload and Share” to generate a shareable link. Your video can easily reach the target audience.
Share Video
Here are some outstanding SaaS product demos:
Office 365’s demo video is memorable for its uncluttered visuals, clear voiceover, and real-life examples. Clearly, it demonstrates how the software tools are compatible with various devices, thereby helping users to be more productive and collaborate efficiently. The video has not given audiences an information overload with technical terms, but rather it has explained the advantages of the product in a clear and confident manner, making it a perfect illustration of a user-centered SaaS demo.
What makes it great:
Office 365 Demo Video
The demo video of SEMrush effectively addresses the complex topic of digital marketing in an impressive way. It avoids the complexities of technical terms, instead clarifying concepts with illustrative examples and simple language. The voiceover is not too fast or too slow, and it is very understandable for both beginners and experts. The video is not overboard with its features for the audience; however, it focuses on the most important benefit: the potential to help people improve their digital presence.
SEMrush Demo Video
The demo video presented by Grammarly focuses on a concept that addresses a common issue. It starts with a familiar issue and immediately brings up Grammarly as the ideal solution. It appears that a normal user in the demo is typing and receiving a grammar check in real-time, making it almost intuitive. Graphic overlays draw attention to corrections and features in the screen, which is helpful to the viewers to have a clear idea of how the tool can work. It is instructive and useful as it demonstrates how Grammarly can be integrated into everyday life.
Grammarly Demo Video
eBay’s demo video focuses on all the intelligent insights of the tool. The eBay Insights intelligence tool demo video is great and convincing that data can be a catalyst for sellers on the platform. It includes examples from the market and demonstrates how the tool helps uncover important metrics, such as demand trends, price strategies, and buyer behavior, to make the right decisions. The easy-to-use control panel, combined with the audio track and users of various levels of analytics expertise, allows the latter to follow the whole story without any difficulties.
eBay Demo Video
Slack’s video demo is not just about the basics. It primarily focuses on the advanced feature, Workflow Builder, highlighting its time-saving capabilities and how it facilitates improved communication with the team. The video is informative and aimed at users who want to get more mileage from the platform in new ways. It provides examples of how processes can be automated and workflows simplified, all with a user-friendly explanation. It is ideal for users who want to elevate their Slack experience.
Slack Product Demo
Any great SaaS product demo video is about clarity, simplicity, and connection. Good demos can help users grasp the usefulness of your product as quickly as possible, even without necessarily reading the story, examining clear visuals, or experiencing real-life applications. To create your showcase demo, select a tool that streamlines the process and gives it a professional appearance. FocuSee is an optimal solution, offering significant advantages, including easy-to-use features such as auto zoom, a built-in teleprompter, variable layouts, online sharing, and more.
