TL;DR:
  • You can record audio from YouTube on PC or Android.
  • Best tools: FocuSee (easy, high quality), Audacity (free, more setup), AZ Screen Recorder.
  • Alternative: use online YouTube → MP3 converters (fast, no install).
  • Always check copyright rules before using the audio.
Are you absolutely in love with certain music or audio on YouTube? Are you looking for ways to access YouTube media without having to launch YouTube every time? If yes, you’ve come to the right place. You can record audio from YouTube.
Record Music Audio from YouTube
There are apps to record audio from YouTube. In this article, you will find the solutions to recording audio from YouTube on your computer or Android devices.
Methods Effectiveness Difficulty
FocuSee High – Frame an area to record YouTube audio. Super easy
Gemoo Recorder High – Choose a specific window to initiate the recording. Easy
Audacity Medium – Support a wide range of formats to export. Easy
Axet Medium – Record audio only, not including video. Medium
AZ Screen Recorder Medium – Record YouTube audio on Android Medium
Take a quick view of the possible solutions and figure out each method in the following parts.
How to Record Audio from YouTube on Computer
In this part, we’ll introduce 3 methods to record music from YouTube on a computer.
Record Audio from YouTube on Computer via FocuSee
While YouTube is a great place to discover new music, it can be frustrating not to be able to easily download songs or add them to your music library. There is a simple way to record audio from YouTube videos playing on your computer – use FocuSee to capture video and high-quality audio from any online content playing on your screen. With this user-friendly screen recorder, you can personalize the specific area you wish to capture, adjust the video speed, and remove any undesired portions after the recording process. Finally, you’ll obtain a gratifying YouTube video recording that is free from superfluous content.
FocuSee’s Key Features
Steps to Record Audio from YouTube via FocuSee
Step 1. Open YouTube and navigate to the audio you want to record.
Launch YouTube and Find the Audio
Step 2. Free install FocuSee and launch it on your computer. On the main interface, choose the Custom recording mode. This will allow you to select the area you want to record. Alternatively, you can choose the Window recording mode to record a full Window.
Choose the Recording Model
Step 3. Frame the recording area and click on the REC button to get started. After a three-second countdown, the recording will start.
Customize the YouTube Recording Area
Step 4. Click on the red Stop button when you finish recording and you’ll be navigated to the video editing interface. In this interface, you can change the video background color, trim unwanted parts, resize the canvas, and make other adjustments to get satisfactory YouTube audio. When you finish editing, click on the Export button that is located in the upper-right corner to save the YouTube audio recording to your computer.
AI Audio Enhancement
Capture YouTube Audio with Free Sound Recorder
Free Sound Recorder is a fantastic tool for recording audio from various social media platforms, including YouTube. It enables you to effortlessly capture music from any online music site, such as Grooveshark and YouTube.
This lightweight program won’t consume much space on your device. Best of all, you can enjoy a vast library of newly released songs and classic albums without spending a dime. Simply record the online music and play it back on your preferred music player!
Preparations Needed:
How to Record Music from YouTube with Free Sound Recorder:
Step 1. Download and Install Free Sound Recorder. Launch the program and open the YouTube audio you want to record.
Step 2. Activate the Recorder. Click the “Record” button to start the online music recorder. Select “Show mixer window” to choose the sound source from the “Recording Mixer.”
Step 3. Select the Recording Device. Choose “Stereo Mix” from the “Recording Device” drop-down menu. Adjust the volume and balance settings as needed.
Step 4. Configure Settings and Start Recording. Go to “Options > General Settings” and select an output format for the YouTube audio. Play the YouTube video you want to record, and click “Start recording.”
Step 5. Finalize the Recording. Once the recording is complete, stop the process and export the file, including details about the artist and song.
Enjoy your recorded audio!
Record Audio from YouTube on Computer via Audacity
If you’ve ever wished you could record music, audiobooks, or podcasts directly from YouTube onto your PC, in this section, you can use Audacity, available for Windows and Mac. Audacity is one of the most well-known free audio recorder applications. Audacity records YouTube audio, helping you to record and edit their audio on Windows and Mac professionally. However, you can also use Audacity for simpler things like recording audio from YouTube.
Record Audio with Audacity
Steps to record audio from YouTube via Audacity
Step 1. Download and launch audacity on your PC.
Step 2. Set the audio host to Windows WASAPI & the recording device to the speaker or headphones you’re using.
Step 3. Now press the record button on the toolbar and play the YouTube video you want to record.
Step 4. After you have recorded the desired audio, click on the stop button.
Step 5. To save the audio on your computer, go to File > Export. You can save the audio in a variety of formats, such as mp3, WAV, etc.
The podcast is now widely used in our daily life. If you need to record audio from a podcast website, get some top podcast recording softwares here.
Also read: How to Change Your YouTube Channel Name
How to Record Audio from YouTube on Android
If you want to record audio directly to your smartphone to enjoy music on the go, here are several apps for Android that can come in handy.
Record YouTube Music on my Phone via Audio Recorder
The Audio Recorder app by Gitlab, developed by Axet, may be the best method to record audio from YouTube videos on Android devices. It is a free app that allows you to record a song from youtube on your phone.
Here’s how:
Step 1. Launch the Audio Recorder app on your Android device.
Step 2. Tap the 3 dots on the top-right corner and go to “Settings.”
Step 3. Select the Recording Source to Internal Audio and the Encoding to your desired format, for example, mp3.
Step 4. Now, go back to the main page and press the microphone button at the bottom of the screen, and start recording.
Step 5. Play the YouTube video you want to record while running the audio recorder in the background.
Step 6. Once you’re done, go back to the app and press the tick on the bottom left of the screen. Your recorded files will appear on the app’s main page and the recordings folder you selected in the settings.
Record Music from my Phone’s YouTube via AZ Screen Recorder
Another option save YouTube videos is to use third-party screen recorders to capture the video you want from YouTube. There are various screen recording apps; however, we will use AZ Screen Recorder for this video.
Once you have screen recorded the YouTube video, you can use a video-to-audio converter to convert it into an audio file. Here are the steps on how to use AZ Screen Recorder:
Install AZ Screen Recorder
Step 1. Record YouTube Video
1. Install and launch the AZ Screen Recorder app.
2. Click the gear icon to access the Settings. Over here, ensure that the toggle for “Record Audio” is on and the “Audio Source” is set to “Internal Audio.”
3. When settings are done, go back to the main screen and press the record icon on the bottom-right of the screen.
4. Go to YouTube and play the video you want to record.
5. When you’re done, go to the AZ Screen Recording app and tap the stop button on the bottom left of the screen.
Step 2. Convert the Recorded Video to MP3
1. For this, download “Video to MP3 Converter” by H-Technologies.
2. Launch the app and select the “Video to Mp3” option from the main page.
3. Go to “Select Video File” and tap “Select Video” to select the recorded YouTube video from your phone.
4. Name the file, select the format to mp3, and the bitrate according to your preference.
5. Then press the convert button. Your converted audio will be available in the “Converted Files” on the main screen.
If you don’t want to go through the hassle of downloading apps, screen recording, and converting files to mp3 format, there’s another straightforward way to get audio from YouTube videos.
Tip. Convert YouTube to MP3 with Online Video Converter
Several websites offer to convert YouTube videos to MP3 without going through time-consuming steps. For instance:
This method is probably the most simple yet effective way to record audio from YouTube. You won’t have to download any software for this; all you need is an internet connection. Plus, it works for both PC and Android devices.
Steps to convert YouTube to MP3
Step 1. Copy the YouTube video URL you wish to get the audio of.
Step 2. Open your browser and enter the URL for Online Video Converter.
Step 3. Paste the URL of the YouTube video you want to convert, and select the format to mp3.
Step 4. Next, click on “Convert.”
Step 5. The video will appear on the screen. Click “Download.”
Step 6. The online tool will convert the video to mp3 and download it to your device, which will be saved in your download folder.
And that’s how you record, convert and download YouTube into mp3 format!
Tips: If you need to record audio from Discord, you can try it on your computer, iPhone, and Android phone.
Final Words
It’s common to see a YouTube video that you like and want to listen to every now and then. However, the issue arises when you’re offline and can’t access YouTube.
Therefore, we have made the process easy for you by listing down several ways to convert, download, and record audio from YouTube videos on your PC and Android device. So, record your favorite sounds any time, anywhere, with the help of the tools mentioned above!
Olivia Bennett
