There are few professional roadblocks more frustrating than having a pristine marketing asset you cannot actually use.
You are likely here because you have a high-end Matterport or 3D link ready to launch. You go to upload the listing to Zillow, Instagram Reels, or TikTok, only to realize these platforms demand a standard video file (MP4), not a 3D web link. You look for a “Download Video” button on your dashboard, but it doesn’t exist.
If you are reading this, you need to know how to turn a virtual tour into a video without sacrificing the immersive quality of the original scan. While 3D platforms excel at interactivity, they often lack native export tools for social media. To convert a virtual tour to video, you generally have to record the tour’s playback on your screen. However, simply hitting “record” often results in a choppy, cursor-filled clip that looks unprofessional.
This guide outlines specific, tested workflows to export a virtual tour as a video that looks cinematic rather than technical.
Before downloading any software, you need to assess the assets you actually have. The “best” method depends entirely on the state of your virtual tour link.
If your Matterport tour has a “Play” button in the bottom-left corner, the platform includes a built-in “Highlight Reel.”
If your link is just a series of dots on the floor with no “Play” button, you must drive the tour manually.
Virtual Tour Decision Tree
Once you know your strategy, you need a tool to capture the screen.
Open Broadcaster Software (OBS) is the industry standard for streaming. It captures exactly what is on your screen.
FocuSee is designed to make a video from a virtual tour by treating screen recordings like editable timelines.
Edit the Video with Auto Zoom Effects
Whether you use OBS or FocuSee, simply hitting “record” will not yield a professional result. The biggest difference between a messy screen recording and a cinematic walkthrough is capture discipline.
To avoid texture “pop-in” (where walls look blurry for a second before sharpening) and stuttering, execute this protocol:
This is an expert insight often missed. Walk through every room you intend to record before you start capturing. This forces your browser to cache the high-resolution textures. If you skip this, your final video will capture the blurry “loading” phase of every room, ruining the immersion.
If your recording comes out black, flickering, or stuttery, check your browser settings.
A cinematic video should not look like a web browser.
Virtual tours move between points via a “warp” or fast fade.
The Trick: Do not click rapidly. Click to move, let the room settle for 3 seconds, then pan slowly. In post-production, you can cut the static time, but you cannot fix a jerky pan.
Bad Capture vs Cinematic Capture
You are likely creating this video for two different audiences. Do not try to make one video fit everywhere. Use your screen recording to create two distinct cuts.
Goal: Stop the scroll. High energy, fast cuts.
Format: Vertical (9:16). You will need to crop the center of your screen recording.
Duration: 15–30 Seconds.
Shot List:
Goal: Replicate an open house. Logical flow.
Format: Widescreen (16:9). Use the full screen capture.
Duration: 2–3 Minutes.
Shot List:
Once the capture is done, you have a raw video file on your computer. To turn a virtual tour into a video that generates leads, you must handle the export correctly.
Most people ruin their video in the final step: sending it to their phone to post on Instagram.
High-resolution scans can reveal family photos, diplomas, or visible mail.
Can I export my virtual tour directly as an MP4?
Generally, no. Most platforms like Matterport or Kuula render 3D environments in real-time using WebGL code, not video files. To share a virtual tour as MP4, you must screen record the playback.
Why is my screen recording black or stuttering?
This is usually a hardware acceleration conflict. Your browser and your recording software are fighting for your Graphics Card (GPU) resources. Go to your browser’s settings, search for “Hardware Acceleration,” and toggle it off. Restart the browser and try recording again.
How do I make the “warp” between rooms look smooth?
If you are clicking manually, the “warp” can look jarring. Ideally, use the platform’s “Autoplay” or “Highlight Reel” feature so the computer handles the transition. If you must click manually, pause for 2 seconds after every click. In your video editor, you can apply a “Cross Dissolve” transition between these static moments to hide the warp entirely.
How do I record without the cursor showing?
If using OBS, right-click your “Display Capture” source, select “Properties,” and uncheck “Capture Cursor.” If using FocuSee, the software automatically offers effects to hide or minimize the cursor in the final export.
You do not need to reshoot the property to get video content; you just need to know how to make a Matterport tour video from the assets you already have.
By following the “Cinematic Recipe”—pre-loading textures, hiding the UI, and using the correct transfer method—you can turn a static link into a dynamic video asset in under 30 minutes.
