High-quality cameras in iPhones and Android smartphones allow us to capture everything that goes on around us, and as a result, we have all become amateur videographers to some extent. We are routinely recording private moments, things we do at work, vacation time, or just random events that happen along the way. Of course, not all those screen recordings turn out well, but we can more or less control what we capture by looking at the screen.
Record with Screen Off on Android
What about situations when it’s not possible to keep the screen on? Is it still possible to keep recording this way? It certainly is, and this article will teach you how to record with the screen off on an Android or iPhone. While you may not be as precise as you normally would, you will be able to record anything you want if you use the right app.
Let’s explore the 3 proven methods to record video screens to get started.
| Methods | Best for | Easy-to-use |
| FocuSee | Especially suitable for recording short marketing videos. | Super easy |
| Background Video Recorder – Android | Record video with Screen off on Andoid. | Easy |
| Camera app – iPhone | Short video clips for personal or social media use. | Easy |
It’s obvious that keeping the screen turned on and using it to monitor what is being recorded makes video creation much easier and more precisely focused. It’s fair to ask why anyone would want to forego this advantage and record without any visual feedback on the device screen. Here are a few scenarios where recording without using the screen makes sense:
When it comes to recording Android or iOS device screens, keeping the recording stable, clear, and compliant is far more important than trying to capture content with the screen turned off. Due to system-level restrictions on both Android and iOS, screen content can only be recorded while the device display is on.
For users who need high-quality mobile screen recordings—such as app demos, tutorials, product walkthroughs, or marketing videos—FocuSee offers a reliable desktop-based solution.
FocuSee allows you to connect your Android phone, tablet, iPhone, or iPad to a computer via USB and record the device screen in real time. This approach ensures smooth performance, accurate visuals, and full control over both recording and editing.
Why Use FocuSee to Record Android or iOS Screens?
Note:
FocuSee records screen content that is actively rendered by the system. For accurate results, ensure the content remains available to the operating system during recording.
Here are the general steps you could take to attempt to record with the screen off on a computer.
Step 1. Free download FocuSee and launch it on your computer. FocuSee provides 4 distinct modes for capturing screen content. You have the option to record your entire screen, select a particular area for customized recording, target a specific application window for capture, or record your mobile phone.
On the main interface, select Device Recording Mode to begin capturing a mobile device screen.
Step 2. Connect your mobile device
For Android devices: Connect your phone or tablet to the computer using a USB cable. Enable USB debugging on the device. Grant the required permissions when prompted.
For iPhone or iPad: Connect the device via USB. Unlock the device and tap “Trust This Computer”. Enter your device passcode if required. Once connected, your mobile screen will be mirrored in FocuSee.
Step 3. Configure your microphone, system audio, and camera (optional). This is especially useful when recording app tutorials or voice-over demonstrations.
Step 4. Click the red REC button. After a 3-second countdown, FocuSee begins recording your Android or iOS screen in real time. You can freely interact with your device while everything is captured clearly on your computer.
Step 5. After recording, FocuSee automatically applies smart zoom effects based on user interactions. You can also trim the video, adjust playback speed, change layout, or highlight key areas to improve clarity and engagement.
Record Android Phone Screen
Step 6. Export your final video in MP4 or GIF format, or upload it to the cloud to generate a shareable link for easy distribution.
There are numerous recording apps compatible with an Android phone, including the native recording function that comes pre-installed. However, if you intend to record with the screen off, you might need to narrow your choices to apps that support this feature. One of the best choices is certainly Background Video Recorder, which you can download for free from the Google Play Store and use for recording anything with your phone.
Background Video Recorder is a lightweight application that accesses your camera and creates HD videos from its input. The commands are very simple, so practically anyone can get solid-looking videos with this app. Most importantly, the app has a mode for background recording that keeps the screen turned off while video is being captured. Here is how to activate this function and create a video:
Step 1. Install Background Video Recorder on your phone and permit it to use the camera
Grant All the Necessary Permissions
Step 2. Open Settings to specify which camera to use and other parameters
Step 3. Choose the option to continue recording when the screen is off
Step 4. Turn the screen off, then press the floating record button that’s visible over the screensaver
Start Recording the Video
Given the fact that the iOS ecosystem consists of different apps than Android, iPhone owners have plenty of unique recording options at their disposal. One possibility that immediately pops up is to use the default camera app that you normally rely on for all recordings. This app could be configured to silently record while the screen is locked, but that’s possible only on older iPhone versions up to iOS 9.
A more reliable option is to find an app like SP Camera that allows you to record anything you want while your screen is dark or shows a fake background. This software was designed for ‘spyware’ purposes and its specialty is allowing users to record without anyone else being aware of it. Here is the procedure you must complete in order to complete this task on any iPhone model, including the latest ones.
Step 1. Download and install the SP Camera app from the App Store
Step 2. Run the app and enter video mode
Step 3. Tap in the bottom left corner of the screen to start recording
Step 4. Optionally, protect the video with a passcode so that no one else can stop the recording
Step 5. Tap the bottom left corner once again (or enter the passcode) to finalize the capture
Further Reading: How to Record Audio on iPhone >
1. Is there a way to ensure a video recording is made even if I am not actively controlling the phone?
If you are using a specialized app for recording with the screen off, there should be a feature that lets you schedule a recording in advance or start it upon the detection of movement. Activating such a feature allows you to simply leave your phone and capture anything that happens while you are away.
2. Is it possible to stop the recording manually without turning on the screen?
A key characteristic of good recorders for silent capturing is that they allow you to control the recording process by tapping on the dark screen or using another discreet mechanism. In this way, you can start or stop recording without anyone else in the room even noticing.
3. How long can I record video from my phone with the screen turned off?
Depending on the recording tool you choose, there could be a time limit for individual recordings (usually 30 or 45 minutes). Other factors that could impact the maximum duration of the video include the status of the battery as well as the availability of working memory.
Recording from a mobile device with the screen turned off is not very comfortable, but sometimes it might be necessary for several reasons. There are lots of tools that make this task less daunting, and they are available for Android, iOS, and PC platforms. It might take some trial and error before you learn how to use such an app discreetly and make a great video without using the screen. This skill will serve you well if you ever find yourself in a situation where you can’t use the screen for whatever reason. How do you record without the screen being active, and are you satisfied with this method?
