Asus laptop computers are fast and powerful and can be used for many different things. Laptop users may also happen to need to record their gameplay screen or video or something else on a Windows or Mac computer. Like most laptop brands, Asus contains some built-in screen recording tools already present on the computer that could make a quick recording of your screen, but those apps are pretty basic and may not satisfy everyone. This article mentions 6 useful tools to help you record screens and also covers all you need to know about how to screen record on an Asus laptop on Windows 11/10.
How to Screen Record on Asus Laptop
How to Screen Record on Asus Laptop Windows 11
Like most computers, the Asus laptop preinstalled a screen recorder tool – Xbox Game Bar. Without needing to download it again, you can enable this feature with shortcut keys. Game Bar is able to grab screen content, but it won’t perform well with more demanding tasks. Content from some apps can’t be captured with this software at all, necessitating the use of screen record software for Windows with more extensive recording, editing, and sharing features. Before using the Xbox Game Bar to record the screen on an Asus laptop, ensure your Asus laptop is running Windows 11 to fit the Optimized version.
Here are the detailed steps to record your Asus laptop screen via the Xbox game bar:
Step 1. Press and hold the Windows + G, and you will open the dialog box that allows you to control the video and audio settings in greater detail.
Open the Xbox Game Bar
Step 2. In the Game Bar, access the Widget Menu and choose the Capture option.
Configure Video and Audio Settings
Step 3. Choose the Start Recording button or press Windows + R to start the screen recording.
Start the Screen Recording
Step 4. When you want to quit recording and finalize the clip, you can press the same combination of keys, or use the stop icon on the bar.
Numerous apps and software compatible with Windows 10 & 11 can capture screen content, but only a select few with a balance of features, usability, and pricing are worth considering. While preferences and use cases vary, we’ve compared the top screen recorders for Asus laptops and recommend options suitable for most users.
When it comes to screen recorders, FocuSee is undoubtedly a good choice. As a professional screen recording tool, FocuSee allows you to screen record on an Asus laptop with the highest 4K resolution. It supports three recording modes: Full Screen/Custom/Windows. You can choose the suitable mode according to your needs. The recorded video output formats can also be chosen from MP4 and GIF as you wish. Besides easy screen recording, this powerful tool also allows you to trim and edit recorded files. Thanks to the user-friendly steps, FocuSee will provide you with the easiest solution for how to screen record on Asus laptop.
Key Features of FocuSee:
Here is guidance on how to record screen on an Asus laptop via FocuSee:
Step 1. Launch FocuSee on the computer and enter your account and password to log in to FocuSee.
Step 2. FocuSee offers three recording modes: Full Screen/Custom/Windows. You can choose the one you want to record.
Choose the Recording Mode
Step 3. FocuSee can handle the post-production automatically during recording. After that, you can change the background, adjust the cursor style, add captions and more.
Post-production Automatically with FocuSee
Step 4. Then, export your recordings as an MP4 or GIF file or share them with a link easily.
Export Your Video
OBS is a well-known open-source software product that excels in several roles, and it can help you capture your screen activity along with native audio. It comes equipped with lots of smart features that make video creation and editing a walk in the park. It’s also possible to stream your broadcasts on the internet directly from OBS, shortening the path from an idea to a video that’s being watched. If you only intend to record your screen with this software, the procedure is quite straightforward and accessible to any user.
Here are steps to record the screen on OBS Studio:
Step 1. Run OBS on your Asus laptop and start a new Scene.
Step 2. Find the Sources box on the screen and click on the + shaped icon.
Step 3. Choose the Capture Display option, and confirm your choice by clicking OK.
Step 4. Open the Settings menu and select Output from the sidebar.
Open the Settings Menu
Step 5. Define the Destination path by picking a folder where the recording will be saved.
Step 6. When you are finished tinkering with settings, click on the Start recording button.
Ezvid is another software product you can use to capture the content of the screen on your Asus laptop. Since Ezvid is freeware and has low system requirements, you can download it to your laptop. With this app, it’s possible to record video or audio and then enhance the recording by adding various elements or changing the video speed. It’s simple and intuitive, with several keyboard shortcuts defined for frequently used commands. However, Ezvid lacks some advanced functions. If you want to add zoom-in effects to your video, you should choose a more professional tool.
Here is how to screen record on Asus laptop:
Step 1. Install Ezvid on your laptop and start the application.
Step 2. Click on the Screen Record button to start recording anything from your screen.
Click the Start Button on Ezvid
Step 3. After you are done recording and editing, choose whether to save the file locally or upload it directly to the internet.
If you are looking for a reliable and user-friendly screen recorder you can install for free, Filmora Scrn should be on your shortlist. This software supports 6 different capturing modes and allows you to pan and zoom across your screen and show all the details you want. It also has impressive editing features and can capture sound from the app or the external microphone. Those characteristics make Filmora a great choice for anyone who wants to create tutorials, talk-head videos, or stream games online.
Just follow those simple steps to record the screen:
Step 1. Start Filmora Scrn on your computer and simultaneously start the app from which you intend to record content.
How to Record Screen on Asus Laptop with Filmora
Step 2. Click on the Rec button to initiate the recording session.
Step 3. During the 3-second countdown, go back to the window you are recording from.
Step 4. Press the F9 key on the keyboard to stop the recording when you are done.
Step 5. The recording will instantly be opened in the editor so that you can apply any changes you want.
CamStudio has many similar functions to other apps on this list, but it presents them in a format that suits users of all experience levels. It can capture still frames or continuous video from any window and lets the user add text and annotations without too much effort. If you want to protect your artwork, adding a watermark on top of the visuals is possible.
Here you can follow the steps below to record the screen on your Asus laptop:
Step 1. Install CamStudio on the Asus laptop and start it.
Step 2. Select the region of the screen that you would like to record.
Select the Region of the Screen
Step 3. Adjust other technical settings such as video quality or compression rate.
Step 4. Hit the red button in the toolbar to start recording.
Another choice is ScreenRec. With this free app installed on your computer, it becomes extremely easy to record the screen whenever you wish to do so. This tool works on every major OS and has very practical and smartly designed features that empower beginners to create very professional-looking materials. It requires almost no training and has pretty simple commands, so you can basically just run with your project right after you download it.
This is how to activate this function:
Step 1. Run the ScreenRec app on your laptop.
Step 2. Simultaneously press the Alt and S keys to choose the region of the screen to be recorded.
Step 3. Click on the microphone icon in the toolbar to choose the audio source.
Step 4. Click on the camera icon in the same toolbar to start recording.
Click on the Camera icon
Step 5. Create a private URL referring to the video that can be shared with selected contacts.
Q1: How to screen record on Asus VivoBook?
The Asus VivoBook is a specific series of laptops under the Asus laptop brand. Therefore, methods to screen record on an Asus VivoBook are the same as ways for an Asus laptop. If you want to screen record on your Asus VivoBook. You can also choose the tools mentioned in the article.
Q2: How difficult is it to include sound in my recordings?
Most apps recommended above support recording system audio as well as microphone sound, and it’s really easy to combine audio with video with just a few clicks.
Q3: Which screen recording software should I download to my Asus laptop?
If you are searching for a way how to screen record on Asus Chromebook laptop, you should carefully consider the features and limitations of each app before downloading your screen recorder of choice.
Q4: How to screen record on Asus TUF Gaming laptop?
On an Asus TUF Gaming laptop, you can screen record by:
Using third-party software
In conclusion, this post mentioned 6 effective tools to help you record screens on an Asus laptop: FocuSee, OBS Studio, Ezvid, Filmora Scrn, CamStudio, and ScreenRec. Among all these choices, FocuSee stands out for its professional designs as well as powerful functions. With its intuitive interface, video trimming and editing are not a difficulty anymore even for beginners.
