Let’s be real, SaaS products can feel overwhelming at first. You sign up, open the dashboard, and boom… menus, buttons, features everywhere. It’s easy to think, “Where do I even start?” That’s where product tours come in.
They guide users step by step, helping them understand how everything works without needing to ask for help or dig through tutorials. In this guide, I’ll explain what product tours are, why they’re so useful, and how you can build one that works even if you have zero coding skills.
The product tour is a very simple step-by-step guide by which new users can understand how to use the app or website more easily. It highlights features to be used and usually achieved with pop-ups, tooltips, or short messages inside the app. Product tour tools allow users to grasp the product sufficiently fast without needing support or going through lengthy documentation.
Step 1: Free download FocuSee on your computer. It just takes a few minutes. Follow the steps shown to pop up on your screen, and you’re set up.
Step 2: Open FocuSee. You’ll see the main screen where you can choose your recording settings.
Here’s what you need to check:
Choose From Options
Step 3: Choose What You Want to Record
FocuSee lets you record:
Step 4: Click on the red REC button when you’re ready. You will get a short countdown so you can take a breather and get into the zone. Now just walk through your product like you’re helping a friend. Show them where to click, what each part does, and any cool features.
FocuSee automatically adds zoom-ins, highlights, and tracks your cursor so your video looks polished without you having to edit.
Record Screen with FocuSee
Step 6: Click the red button again to stop. That’s it, you’ve got your video. After recording, you can trim, slow down, speed up, or highlight areas in the video. But honestly, FocuSee already makes it look good on its own.
Product tours can either break or make a new user’s experience at first. Luckily, there are some great product tour tools out there that can make the whole process super easy for creating really helpful, beautiful, and effective product walkthroughs. Whether you’re tech-savvy or only just starting, this product walkthrough software will make your life a whole lot easier.
Turn Simple Recordings into Stunning Product Tours
FocuSee takes the hassle out of making product tour videos. You just hit “record,” and the magic happens automatically. It tracks your mouse, zooms in on the important parts, adds click effects, and even gives your video a clean background, all without you lifting a finger.
No need to mess around with timelines or edit frame by frame. It is perfect for onboarding videos, tutorials, product demos, or even social media launches. The FocuSee dashboard makes creators, marketers, and product managers look like pros.
FocuSee Official Website
Key Features
Pros
Cons
Pricing
Best Product Tour Tool for Startups & Small Teams
UserGuiding is perfect if you want to launch helpful product tours quickly without touching any code. Small teams can guide their new users to better onboard and provide feedback without breaking the bank or hiring a dev. Building interactive guides, tooltips, checklists, and modals, using nothing but a simple Chrome extension. Lightweight, easy to use, and scalable with growth.
Best Product Tour Tools – UserGuiding
Key Features
Pros
Cons
Pricing
Best for Personalized Product Experiences with Deep Insights
Appcues helps you create cool experiences to assist users from day one and continue guiding them at each stage of the customer journey. Build flows, tooltips, surveys, and checklists posting via drag and drop within its framework. Appcues also gives you user statistics, Lick tracking with behavioral data that shows what works and what does not.
Best Product Tour Tools – Appcues
Key Features
Pros
Cons
Pricing
Why should I invest in a guided product tour?
If someone opens your app and feels lost, they are more likely to shut the app and move on. The product tours act as a friendly guide showing users where to go, what to do. A small effort goes a long way.
How long should a product tour be?
Keep them short and sweet. The best product tours are less than 2–3 minutes long or maybe 5-7 steps. Just give them the key actions they need to be looking at, and just let them loose to explore the rest.
What is Intercom Product Tours?
Intercom Product Tours is another popular one on our list. It essentially allows product managers to build step-by-step guides within the app using tooltips, messages, and pop-ups. Perfect for onboarding users or for walking them through new features.
Are product tour tools hard to use?
Not at all! Anyone developing a product tour, these days, would be interested in a no-code or beginner-friendly tool. Drag, drop, and customize: No coder needed! You can build something really attractive and engaging using tools like FocuSee, UserGuiding, Appcues, and Presently without writing a single bit of code.
Having great product tours is less about showing features but actually making users feel comfortable with your product. Guided and well-supported users are likely to stay around, end up exploring the product, and enjoying what you’ve built. You may not be a technical wizard, but that certainly doesn’t mean you can’t create something amazing. With tools like FocuSee, you could create beautiful, engaging product tour videos within a few clicks, no hassle, no code, just results.
