If you’re a gamer and have been using NVIDIA ShadowPlay to capture gameplay moments, but suddenly find that it’s not recording, it can be quite frustrating. ShadowPlay, known for its high-quality game recording with minimal performance impact, can sometimes encounter issues due to various reasons such as software conflicts, outdated drivers, or incorrect settings.
How to Fix Nvidia Shadowplay Not Recording
In this guide, we’ll explore several troubleshooting steps to help you resolve the problem when ShadowPlay isn’t recording as expected. We’ll cover checking for updates, adjusting settings, and other potential fixes to get your gameplay recording back on track. Also, we’ll introduce an alternative way to record gameplay like Nvidia Shadowplay. Let’s dive into the solutions that could help you get ShadowPlay working smoothly again.
If you’re experiencing issues with NVIDIA ShadowPlay not recording as of 2025, there could be several reasons behind the problem. Here are some potential causes and solutions based on the information available:
ShadowPlay, developed by NVIDIA as a part of its GeForce Experience software, can randomly stop recording due to several potential issues. Common reasons include software bugs or glitches, insufficient disk space, or conflicts with system settings or other software. Additionally, overheating of the GPU or issues with the GPU driver can disrupt the recording process. Another factor could be the settings within ShadowPlay itself, such as the temporary file storage limit being reached or specific in-game settings that ShadowPlay might struggle to handle consistently. To address these issues, users should ensure their drivers are up to date, check for adequate disk space, monitor their GPU temperature, and adjust ShadowPlay settings as needed.
If you’re experiencing issues with NVIDIA ShadowPlay not recording, there are several troubleshooting steps you can take to resolve the problem. Here’s a detailed guide to help you fix issues with NVIDIA ShadowPlay:
Restart GeForce Experience
Sometimes, a simple restart of the GeForce Experience software can resolve recording issues. Close the application entirely and then reopen it.
Reinstall GeForce Experience
If none of the above steps work, try uninstalling and then reinstalling GeForce Experience. This can fix issues caused by corrupt installation files.
Update GPU Drivers
Make sure your NVIDIA drivers are up to date, as outdated drivers can often cause problems with recording software. You can update your drivers through the NVIDIA GeForce Experience app or download them directly from the NVIDIA website.
Review Recording Settings
Double-check the recording settings within ShadowPlay to ensure they are configured correctly for your desired recording quality and format.
Enable Privacy Control
ShadowPlay might not record due to privacy restrictions in certain applications, especially games. Go to GeForce Experience, click on the Settings gear icon, and under the General tab, make sure that “In-game overlay” is enabled and check the settings in “Privacy control” to allow desktop capture.
Check Disk Space
Ensure that you have sufficient disk space on the drive where the recordings are saved. ShadowPlay may stop recording or fail to start if there’s not enough space.
Run as Administrator
Try running GeForce Experience as an administrator. Right-click the GeForce Experience shortcut and select “Run as administrator.” This can help resolve permission issues that might be preventing recording.
Adjust ShadowPlay Settings
Open the in-game overlay by pressing Alt+Z, go to the Recordings section, and check your recording settings. Make sure the correct audio devices are selected, and adjust the video quality settings to see if a lower setting resolves the issue.
Other overlay applications (like Discord overlay, Steam overlay, etc.) can interfere with ShadowPlay. Try disabling these overlays to see if ShadowPlay starts working.
Check Antivirus Software
Sometimes, antivirus software can block ShadowPlay from recording. Check your antivirus settings and make sure GeForce Experience and ShadowPlay are allowed through your firewall.
If none of the above steps work, consider reaching out to NVIDIA’s customer support for further assistance.
If you’re looking for alternative ways to record your screen similar to what NVIDIA ShadowPlay offers, there are several lightweight screen recording tools you can consider. Among the most popular screen recorders in 2025, FocuSee is a versatile video recording and editing tool that can serve as an alternative to ShadowPlay. It supports recording with high resolution and has a simple interface that’s easy to navigate. You can automatically apply an auto zoom-in effect during the recording and generate subtitles after recording.
Step 1. Free install FocuSee and open it on your computer. Choose a screen recording mode and click the REC button to process.
Choose a Recording Mode
Step 2. Click where you want during the recording. Then FocuSee will automatically zoom in on specific elements.
Frame an Area to Record
Step 3. When you complete the recording, tap the red Stop icon to return to the video editing interface.
Edit Your Video Clip
In conclusion, resolving issues with NVIDIA ShadowPlay not recording involves a series of straightforward troubleshooting steps. By methodically following these steps, users can typically overcome difficulties with ShadowPlay and restore its recording functionality, ensuring they continue to capture their gameplay and other screen activities effectively.
