You’re trying to record a tutorial, capture an epic gaming moment, or share something hilarious from an app, but there’s a problem: your iPhone screen recording has no sound. It’s a frustrating issue that can bring your screen-capturing endeavors to a screeching halt.
Don’t worry – silence doesn’t have to be golden (or in this case, incredibly annoying). This guide will walk you through the common culprits behind iPhone screen recording audio issues and provide you with a range of troubleshooting steps to get your sound back on track. From simple restarts to checking microphone permissions and exploring hardware possibilities, we’ll cover it all.
Before we jump into solutions, let’s understand why your iPhone screen recording might be missing audio.
Possible Causes of No Sound:
Before you begin, please check the following aspects:
A simple restart can resolve many minor software glitches. To restart: Press and hold the side button and either volume button until the “slide to power off” slider appears. Slide to power off, wait 30 seconds, then press and hold the side button again to turn it back on.
Restart Your iPhone
For Screen Recording: Go to Settings > Privacy > Microphone. Make sure the “Screen Recording” toggle is enabled (green).
Check Microphone Permissions
For Specific Apps: If you’re having trouble recording sound from a particular app, check its microphone permissions in Settings > Privacy > Microphone.
Sometimes, Bluetooth can affect your screen recording on the iPhone, so disable Bluetooth on your iPhone:
Go to Settings > Bluetooth and toggle Bluetooth off > Try recording your screen again to see if the audio is captured.
Disable Bluetooth
Outdated iOS versions can have bugs. To check for updates: Go to Settings > General > Software Update. If an update is available, download and install it.
Check for iOS Update
Warning: This will erase all your personalized settings. Back up your iPhone before proceeding.
Go to Settings > General > Transfer or Reset iPhone > Reset > Reset All Settings.
Tap on Reset All Settings
If you suspect a hardware issue, contact Apple Support or visit an authorized service provider for further diagnosis and repair options.
If you need to record screen on your computer, consider FocuSee as your first choice. It is an indispensable screen recording solution and is perfectly tailored to meet your needs. It provides you with the freedom to record the entire screen, a custom section, or a specific window.
Ideal for crafting detailed tutorials, capturing immersive gameplay, and showcasing product demonstrations, it seamlessly integrates auto zoom capabilities when recording the screen. This feature focuses on the action and enhances viewer engagement. It works well on both Mac and Windows platforms, enhancing the visual impact of your recordings.
Key Features of FocuSee:
Step 1. Free download and launch FocuSee on the computer and enter your account and password to log in to FocuSee.
Step 2. FocuSee supports 3 recording modes: record the full screen, custom the recording area, or record the window. You can choose the one you want to record.
Three Recording Modes for FocuSee
Step 3. After choosing the recording mode, please just focus on your screen recordings. Let FocuSee handle the post-production automatically. You can get a visually appealing video as soon as you finish recording. After recording, you can change the background, adjust the cursor style, add captions and more.
Screen Recording Editing Interface
Step 4. Then, export your recordings as an MP4 or GIF file or share it with a link easily.
How to Export the Video
A silent screen recording can be incredibly frustrating, but with a little troubleshooting, you can usually get your audio back. By systematically working through the software and hardware solutions outlined in this guide, you’ll greatly increase your chances of fixing the problem and returning to capturing those epic screen recordings with crystal-clear sound.
If you’ve discovered other solutions or have any tips to share, feel free to leave a comment below. Your experiences might help fellow iPhone users facing the same issue!
Q: Why is my iPhone screen recording only capturing my voice and not the game audio?
A: You likely need to enable “Microphone Audio” in the Control Center while recording. This allows the screen recording to capture your iPhone’s internal audio in addition to microphone input.
Q: Can I record my iPhone screen with sound using a wired headset?
A: Yes, but you might need to select the headset as the audio input source in the Control Center before you start recording.
Q: Does the Spectrum TV app allow simultaneous recording?
A: Yes, the Spectrum TV app often allows simultaneous recordings of multiple shows, but the exact number depends on your specific plan. Check with Spectrum for details on your plan’s capabilities.
