TikTok Live has become popular and offers a dynamic real-time interaction, entertainment, and even education platform. From impromptu performances and Q&A sessions to exclusive behind-the-scenes glimpses, viewers are glued to these live streams for a reason. But what happens when you want to relive a hilarious moment, rewatch a tutorial, or share a stream with friends who missed it?
That’s where screen recording saves the day! By capturing TikTok Live streams directly from your device, you can save and enjoy those fleeting moments anytime.
TikTok Live is a feature that allows creators to connect with their audience in real time. Viewers can join live streams, interact through comments and reactions, send virtual gifts, and participate in Q&A sessions. It’s a dynamic and engaging way to experience TikTok content, but there’s a catch—live streams are ephemeral. Once they end, they’re gone (unless the creator saves them).
What is TikTok Live
For Windows users, there are powerful yet user-friendly screen recording tools that make capturing TikTok Live streams a breeze. One such tool is FocuSee, a screen recorder designed with simplicity and efficiency in mind.
FocuSee is a lightweight and intuitive screen recording software for Windows and Mac users that makes capturing TikTok Live streams a breeze. It offers a range of features that make it ideal for this task, including:
Here’s how to record TikTok Live on Windows using FocuSee:
Step 1: Free download FocuSee and launch it. Frame and adjust the recording area to precisely cover the TikTok Live stream window. Configure your desired Setup. Choose “System audio” for the live stream’s sound, “Microphone” for your commentary.
Choose the Custom Recording Mode
Step 2: Click the red REC button in FocuSee when the TikTok Live stream begins. Click the Stop icon in FocuSee when the live stream ends.
Frame the TikTok Live to Record
Step 3: FocuSee will open the recorded video. Preview it, make any necessary edits (trimming, adding effects), and export it to your desired location.
Edit the TikTok Recording
Mac users have a powerful advantage: a built-in screen recording tool that’s readily available without requiring any additional downloads or installations. QuickTime Player, a familiar tool for media playback, is also a capable screen recorder, making it a convenient choice for capturing TikTok Live streams.
Here’s how to screen record TikTok Live on Mac using QuickTime Player:
Record Google Translate Voice via QuickTime Player
Step 1: Open QuickTime Player from your Applications folder.
Step 2: From the File menu, choose “New Screen Recording.”
Step 3: Click the arrow next to the record button.
Step 4: Choose your recording area (entire screen or a portion) and select “System audio” for the TikTok Live stream’s sound.
Step 5: Click the record button. To record the whole screen, click anywhere. To record a portion, drag to select the area and click “Start Recording” within it.
Step 6: When the live stream ends, click the stop button (black square icon) in the menu bar.
Capturing TikTok Live streams directly on your iPhone or iPad is incredibly easy thanks to the built-in screen recorder introduced in iOS 11. It’s a seamless and intuitive way to record anything happening on your screen, including those must-see TikTok Live moments.
Here’s how to record TikTok Live on iOS using the built-in screen recorder:
Step 1: (If needed) Add Screen Recording to Control Center:
Record TikTok Live iOS
Step 2: Open Control Center (swipe down from the top-right or up from the bottom).
Step 3: Tap the screen recording button (white circle). Wait for the 3-second countdown.
Step 4: Open the TikTok app and start watching the Live stream.
Step 5: To stop, open Control Center again and tap the red recording button or the red status bar at the top.
Step 6: Find your recording in the Photos app.
Android users have several options for recording TikTok Live streams. Some Android devices come with a built-in screen recorder, while others may require a third-party app. If you want more features and more control, AZ Screen Recorder is a popular and reliable third-party option.
Here’s how to record TikTok Live on Android using AZ Screen Recorder:
Step 1: Download and install AZ Screen Recorder from the Google Play Store.
Download AZ Screen Recorder
Step 2: Open AZ Screen Recorder and adjust settings like resolution, frame rate, and audio source. Choose “Internal audio” to capture the live stream’s sound.
Step 3: Tap the red camera icon in the AZ Screen Recorder controls to start recording.
Step 4: Tap the red square icon to stop recording.
Step 5: Your recording will be saved to your device’s gallery. Access it through AZ Screen Recorder or your phone’s gallery app.
1. Is it legal to screen record TikTok Live streams?
Generally, recording TikTok Live streams for personal use is considered acceptable. However, distributing or monetizing someone else’s content without their permission could violate copyright laws. It’s always best to err on the side of caution and respect the creator’s rights.
2. Can I record TikTok Live streams without the host knowing?
Yes, screen recording happens locally on your device, so the host of the TikTok Live stream won’t be notified that you’re recording.
3. What is the best quality to record TikTok Live streams at?
The best quality depends on your device’s capabilities and your storage space. If possible, aim for 1080p resolution and 30fps for a good balance of quality and file size.
4. Can you save live recordings on Instagram?
Yes, you can save live recordings on Instagram, but there are certain conditions and methods to do so. For the person hosting the live video (the broadcaster), Instagram provides a feature called “Live Archive” that allows them to save their live videos for up to 30 days after the broadcast ends. This feature must be enabled in the user’s settings to work, and once enabled, it allows the broadcaster to revisit, share, or download their live videos during this period.
If you are a viewer and want to save a live video, you cannot directly download Instagram Live videos unless the broadcaster shares the video on Instagram after the live session, or you use a third-party tool or method. Some third-party applications and websites claim to allow the downloading of Instagram Live videos, and screen recording is another method that can be used on both desktop and mobile devices.
From built-in tools to user-friendly apps, capturing TikTok Live streams is easier than ever. Whether you’re on Windows, Mac, iOS, or Android, the methods outlined in this guide empower you to save, revisit, and share those special live moments. So go ahead, hit that record button, and make those TikTok Live experiences last!
