Making a short video from the content of your screen is a quick and simple way to express yourself in a multimedia format. You can use it to produce funny, educational, or professional videos, and most importantly, you don’t need a professional cameraman and editor to help you with it. This task can be accomplished on any computer, but if you own a premium brand like HP, you will have very good options to choose from in terms of software tools.
How to Screen Record on HP Laptop
This article will teach you how to record the screen on an HP laptop with sound without any professional assistance. We will present several video recorders for PC that have been proven effective in this role and explain exactly how to use them to capture and record the content of your screen. Equipped with this knowledge, you will gain an opportunity to elevate your media-making skills to the next level and ensure that all of your videos are of high quality and catch all the relevant details that you wanted to include.
Also read:
How to Screen Record on Surface Pro >
How to Screen Record on Thinkpad >
How to Screen Record on HP Laptop?
Way 1. Screen Record on HP Laptop via FocuSee
Way 2. Screen Record on HP Laptop via Gemoo Recorder
Way 3. Screen Record on HP Laptop via Windows Built-in Game Bar
Way 4. Screen Record on HP Laptop via Screencast-O-Matic
Way 5. Screen Record on HP Laptop via TinyTake
If you intend to use only the content of your screen and system audio in your video, you don’t depend on the quality of your webcam and microphone. Instead, you need to find the right software tool for this job and use it aptly to capture everything you need in one take. There are multiple free apps that allow you to make sharp and smooth-running videos containing your computer screen, so you should pick the one that meets all of your requirements and fits your skill level. Here are some options worth trying.
FocuSee is a powerful screen recording tool designed for HP laptops that offers a wide range of features to create engaging and professional-looking videos. With FocuSee, you can easily record your screen, webcam, or both simultaneously, and customize your recordings with various layouts, effects, and enhancements. The software automatically generates captions for your videos and allows you to edit them for perfect accuracy.
FocuSee’s Key Features
How to Use FocuSee to Record Your Screen
Step 1. Install FocuSee for free on your Windows or Mac computer and launch it > Run the application, then click on the “Custom” option on the welcome page.
Choose a Recording Mode
Step 2. When you’re ready, click the “Record” button to start the recording process. During the recording, FocuSee will automatically apply zoom effects based on your mouse cursor clicks and movements.
Frame an Area to Record
Step 3. When you need to stop recording, click on the red “Stop” icon on the left toolbar. You will then enter the video editing interface.
If you would prefer to have a screen recorder installed on your HP laptop or other Windows computer, Gemoo Recorder is a trustworthy option to consider. You can free install Gemoo Recorder or free use this open-source tool on Gemoo’s website platform. With the help of Gemoo Recorder, you can record and create videos whenever you like. It doesn’t limit the length of your recordings or include any watermark, which makes it ideal for people who occasionally create videos but don’t need an expensive professional tool. Here, we collect a list of Gemoo Recorder’s key features to help you have a better understanding of Gemoo Recorder.
Gemoo Recorder’s Key Features
How to Use Gemoo Recorder to Record Your Screen
Step 1. Install Gemoo Recorder on your HP laptop and open it. Click on the Screen Only icon and enable the microphone.
Launch Gemoo Recorder and Choose the Screen Only Mode
Step 2. Hit the Start Recording button and wait for 3 seconds to get started. During the recording process, you can add texts and other annotations via choosing from the left sidebar.
Start to Record the Screen
Step 3. Click on the Red Stop button or the Finish Recording button to complete this step and now you can preview your recordings.
Finish Screen Recording
If you have Windows 10 OS on your HP laptop, you can use the built-in feature called Xbox Game Bar to record the content of your screen very easily. While this tool is primarily intended for capturing game action, it can record from many applications that are not exactly games, although there are some things you can’t record (i.e. desktop). It’s also necessary to enable this option on your computer, but once you do, it’s very simple to start recording screen on PC by executing a few simple steps:
Step 1. Open the application you would like to record.
Step 2. Press the Windows logo key together with G key to run the Game Bar.
Step 3. Click on the red dot icon in the bar to start recording, or alternatively press Windows key with Alt and R if you are in full screen mode at the moment.
Open Xbox Game Bar
This is very simple but effective screen recording software that practically anyone can use. If you don’t know how to record audio on HP laptop, Screencast-O-Matic will let you handle all tasks of this nature from a friendly user interface, directly from a web browser on your HP laptop. The free version of this software tool can create great-looking videos consisting of anything you do on your computer that lasts up to 15 minutes. Here is what you need to do in order to make a screen recording using this practical video making tool:
Step 1. Open any browser you regularly use and go to their website.
Step 2. Click on the Launch screen recorder button from the homepage.
Step 3. After the recorder module launches, click on Start recording and go back to the screen that you want to capture.
Screencast-O-Matic Interface
You don’t need a lot of technical knowledge to create recordings with this amazing free tool. TinyTake lets you capture your screen, edit the recording, add comments or titles, and share the finished work very easily. It’s also very user-friendly and full of cool features and effects that will help you create something truly special without too much effort. To start recording the content of your laptop screen with TinyTake, just do the following:
Step 1. Install TinyTake on your computer and launch it.
TinyTake Interface
Step 2. Click on the Capture button from the app’s interface.
Step 3. Select whether you want to record the entire screen or just a specific region.
Part 4. How to screen record on HP laptop with sound.
Adding sound to your videos certainly makes them more watchable, so it’s important to include this element in your recordings whenever you can. There are two types of audio you might decide to use – system sound from the computer, or your voice and other ambient sounds recorded by a microphone. Most screen recorders support both of those modes, but you may need to set up the audio source you want before you start creating your video.
In this part, we collect a list of frequently-asked questions about screen recording on HP laptops.
This depends on the screen recording software you are using and the way it has been set up. Check whether the audio channel is enabled in the Settings of the screen recorder before you try making a video.
All of the applications described in this article are very simple to use and can be mastered with just a little bit of practice. If you already have the built-in recorder on your computer, try it first and go from there.
Some screen recorders have basic editing tools integrated, so you can improve your video even if your media creation skills are quite rudimentary.
This article shows you how to screen record on computer. If you are using HP computer running Windows 10 users can activate the built-in feature, but there are also quite a few of worthy alternatives. All of the recommended tools are free to use, so it won’t cost you anything to try them out and see whether they can deliver the type of quality you are looking for. It’s very likely that you won’t need a paid screen recorder for this task.
