CapCut, a powerful and user-friendly video editing app, has taken the content creation world by storm. One of its most sought-after features is the ability to zoom in on videos, allowing creators to add emphasis, focus on details, and create engaging visual effects. In this article, we’ll explore various methods to zoom in on your CapCut videos, including step-by-step guides for both mobile and PC users, as well as how to achieve slow zoom and 3D zoom effects.
Zooming in on a video in CapCut is a simple process that can be achieved with just a few taps on your mobile device. By adjusting the zoom level, you can draw the viewer’s attention to specific areas of the frame, highlighting important details or creating a sense of depth and movement.
Steps to zoom in on a CapCut video:
Step 1: Open CapCut on your PC and import the video you want to edit.
Import the Video Clips
Step 2: Place the playhead on the timeline where you want the zoom effect to start.
Step 3: Click on the “Features” button in the toolbar and select the “Zoom” option.
Step 4: Adjust the zoom level by dragging the zoom slider or manually entering a value. You can also reposition the zoom center by dragging the frame in the preview window.
Step 5: Set the duration of the zoom effect by dragging the edges of the zoom layer on the timeline. You can also fine-tune the start and end points of the zoom by dragging the layer.
Apply This Effect
Step 6: If desired, add additional zoom effects to other parts of your video by repeating steps 2-5. Once you’re satisfied with the zoom effects, export your video by clicking the “Export” button and selecting your preferred settings.
Creating a slow zoom effect in CapCut can add a sense of drama, suspense, or focus to your video. By gradually zooming in on a subject, you can guide the viewer’s attention and create a more engaging viewing experience.
Steps to create a slow zoom effect in CapCut:
Step 1: Select the video clip you want to apply the slow zoom effect to.
Step 2: Tap on the “Edit” button and choose the “Zoom” option.
Step 3: Adjust the zoom level to the starting point of your slow zoom.
Step 4: Tap on the “Keyframe” button to create a new keyframe at the beginning of the clip.
Step 5: Move the playhead to the end of the clip and adjust the zoom level to the desired endpoint.
Step 6: CapCut automatically creates a smooth, slow zoom transition between the two keyframes.
Step 7: Tap on the checkmark icon to apply the effect.
The 3D zoom effect in CapCut adds an extra layer of depth and dynamism to your videos. By combining zooming and panning techniques, you can create a sense of movement and depth that draws the viewer into the scene.
Steps to create a 3D zoom effect in CapCut:
Step 1: Select the video clip you want to apply the 3D zoom effect to.
Step 2: Tap on the “Edit” button and choose the “3D Zoom” option from the effects menu.
Step 3: Adjust the starting and ending points of the 3D zoom using the on-screen handles.
Step 4: Use the “Rotation” and “Perspective” sliders to fine-tune the 3D zoom effect.
Step 5: Preview the effect and make any necessary adjustments.
Step 6: Tap on the checkmark icon to apply the 3D zoom effect to your video.
How to Do 3D Photo Trend
CapCut is suitable for rough cut editing on mobile phones, but if you want to further edit your videos, you’ll need PC or online video editing software. CapUP is a powerful online video editing platform designed for content creators, aiming to help them easily create engaging short videos. CapUp utilizes AI technology to analyze subtitles and automatically generate Zoom effects.
By combining eye-catching subtitles that double-emphasize key points, it enhances the visual impact of the video, effortlessly increasing video views and engagement. CapUp comes with top influencer-style Zoom opening effects and sound effects, allowing your videos to capture users’ attention within 3 seconds, easily boosting video play counts and engagement!
Highlight Features of CapUp
Step 1: Log in to CapUp
Log in to your CapUp account. If you don’t have an account, create a new one. Click the “Upload” button and then select the video you want to add subtitles to. Alternatively, drag and drop the video file to the designated upload area.
Log in and Upload the Video
Step 2: Select the video language
Select the language used for the YouTube short video from the drop-down menu. CapUp supports multiple languages to meet your specific needs.
Select the Language that Matches Your Video
Step 3: Generate subtitles automatically
Select the desired template and click the “Save as Template” button to start the AI-driven subtitle generation process.CapUp will analyze your video audio and automatically create accurate, engaging subtitles.
Add Captions to Video Automatically with AI
Step 4: Review and customize subtitles
Once the subtitles are generated, check them for accuracy and make any necessary edits. Use CapUp’s customization options to personalize the look of your captions. Choose from a variety of font styles, sizes, colors, and backgrounds to match your brand’s aesthetic.
Add Subtitles to Videos
Step 5: Export and download
Once you are satisfied with your captions and sound effects, click the Export button.
1. Can I zoom in on a specific part of the video?
Yes, you can zoom in on any part of the video by adjusting the zoom level and repositioning the video frame in the preview window.
2. Is it possible to combine multiple zoom effects in one video?
Yes, you can apply different zoom effects to different parts of your video by splitting the clip and editing each segment separately.
3. Can I adjust the speed of the slow zoom effect?
Yes, you can control the speed of the slow zoom effect by adjusting the distance between the keyframes. The further apart the keyframes, the slower the zoom will be.
CapCut’s zoom features offer a wide range of creative possibilities for content creators looking to enhance their videos. By mastering techniques like basic zooming, slow zoom, and 3D zoom, you can add depth, focus, and visual interest to your content. Whether you’re editing on mobile or PC, CapCut’s intuitive interface and powerful tools make it easy to achieve professional-looking results. So, experiment with these zoom techniques and take your video editing skills to the next level!
